251customs Posted March 25, 2008 Report Share Posted March 25, 2008 i need to know how to check the output of an amp using a volt meter i know there is a formula or something and also my buddy said u can set your amp using a volt meter???? i need some help on this 02 dodge ram quad cab 4.7 pioneer 9800bt pioneer 5700 dvd(yes 2 headunits 5700 for dvd only) 1 re xxx 15 (new style in center console) 4 18" fi btls in snugtop 12 mb quart 6.5s original ones not maxxsonics (kicks, 3 in each front door 2 in each back door) quart 4" dash sp 2 soundstream xxx6500s 1 pd asa1000.1 for the xxx15 4 pb asa600.4 highs 4 7" screens 1 15" flipdown 2 red tops 16 g31 yellow tops playstation 2 4 8x11 p.a. horns under truck (music plays through them) db 80.2 for horns 2 underglow kits (1 flex kit in fenderwells) 24" martin bros vampires Link to comment Share on other sites More sharing options...
Boon Posted March 25, 2008 Report Share Posted March 25, 2008 Why is this in the videos section :S To answer your question, set the multimeter to AC Voltage then put it across the outputs of your amp. Play a 50hz tone (for sub amps...) and write down the voltage. Then put the multimetre on Resistance, play the tone and write down what you get. Voltage squared divided by resistance = power, I'm pretty sure. So 50w @ 4 ohm = x^2 /4 so voltage = square root of 200, or 14.14 Likewise 10v @ 1 ohm = 100w 10.x volts fo' life! Link to comment Share on other sites More sharing options...
Torres Posted March 25, 2008 Report Share Posted March 25, 2008 click the link in my sig. the RMS chart. goes from 100 watts to 5000, showing you what your meter should be reading on the outputs of the amp at the given ohms. might find it helpful Link to comment Share on other sites More sharing options...
tacomabanga1986 Posted March 26, 2008 Report Share Posted March 26, 2008 do you leave subs hooked up when doin this test or disconect em but if u do how do u get the ohm load for the power output? lol its wierd but i wanna try it here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp here's a link to my other system my 90 geo prizm test car heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit Link to comment Share on other sites More sharing options...
Torres Posted March 26, 2008 Report Share Posted March 26, 2008 unhook the subs. put the test tone in (50-60 hz) on my chart, you just match up the power you want to the given ohm load. 200 watts at 2 ohms would be 20 volts. that's what you'd want the amp to put out if you were using a 2 ohm configuration Link to comment Share on other sites More sharing options...
stilltippin863 Posted March 29, 2008 Report Share Posted March 29, 2008 unhook the subs. put the test tone in (50-60 hz) on my chart, you just match up the power you want to the given ohm load. 200 watts at 2 ohms would be 20 volts. that's what you'd want the amp to put out if you were using a 2 ohm configuration well what if i am playing my vol at 3/4 of the way and a 50 hz tone ar 2ohm what would i be looking for on the DMM when i am turning up the gain??? what do i stop at?? 70.71??? i got a zx2500.1 kicker amp pushing 4 15 L5 solo baric squares Link to comment Share on other sites More sharing options...
Boon Posted March 30, 2008 Report Share Posted March 30, 2008 well what if i am playing my vol at 3/4 of the way and a 50 hz tone ar 2ohm what would i be looking for on the DMM when i am turning up the gain??? what do i stop at?? 70.71??? i got a zx2500.1 kicker amp pushing 4 15 L5 solo baric squares Yes, theoretically. Although I find it hard to believe that amp makes 2500wrms @ 2 ohms. See if you can get access to an oscilloscope 10.x volts fo' life! Link to comment Share on other sites More sharing options...
EricM9104 Posted March 30, 2008 Report Share Posted March 30, 2008 Although I find it hard to believe that amp makes 2500wrms @ 2 ohms. Why do you say that? I've heard of some ZX2500.1's with a birthsheet of 2,500+w RMS @ 2 ohms. 2015 Honda Civic LX 4dr | 24k miles Stock H/U and mids/highs Power Acoustik GW3-12" D2 Sub HiFonics BXX1200.1D @ 1ohm Random 2.5^3' dual ported box NVX LOC Stinger wiring throughout 1977 Chevy SWB Cammed 350 Dual exhaust Cheap Wish stereo Link to comment Share on other sites More sharing options...
