will 2 subwoofers pull more current than a single sub?
will a 2 subs pull more current from an amp than a single sub even if the amp is tuned the same way as the single sub was? went from a single 2 ohm sub wired at 1 ohm to 2 subs of the same model but this time dual 4 ohm wired down to 1 ohm
If the impedance at the amp is the same then the load on it should also be the same. Adding a sub just divides the power sent to it (givin that all other variables remain constant).
I think what asking is if there will be a difference in the performance of the amp with two subs vs one.
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- (4) Crescendo PWX 6
- Cadence XA250.2
SUB STAGE:
-Fi Audio BL 15 (Sealed Off)
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
- SkyHigh OFC power/speaker wire
- Big 3 with SkyHigh 0gauge
Build Log: Click Here
Scores: 146.5db @ 29hz Outlaw
  • Who's Online   0 Members, 0 Anonymous, 7073 Guests (See full list)
