I just bought a 2014 Tacoma. I have a box I built for behind the seats from my 07 tacoma I traded off. I'd like it in this truck. I like the factory deck but plan to upgrade everything else over time. What processing units do you all recommend? I'm looking at the audio control LC7i. Are they worth their money?
2000 Cavalier 4 door
XS D925
XS D2400
XS D3100
4 runs of 1/0
Mechman 270
2 DD 9515js
Do you have experience with them?
I do, but if you are planning to upgrade everything later on, why not just invest it towards a headunit, that way you can bypass having to get one...unless your truck comes with a factory upgraded sound system and everything is synced to your radio, then that would be a diff topic...but the LCi7 is designed to take your factory signals and converts them into high quality, aftermarket low-noise, pre-amp level signals.
What are you planning to do? Just adding bass? Or a full system?
My truck has a really nice factory head unit. It's the Entune upgrade. I plan on eventually putting an amp on the factory midst and high as well as adding my sub stage I already have. Just looking for better quality than your run of the mill cheap LOC.
XS D925
XS D2400
XS D3100
4 runs of 1/0
Mechman 270
2 DD 9515js
The LCi7 is a good LOC, but it does not have EQ capabilities. You will need to purchase a separate eq, crossover, or a processor for you to be able to do that, unless your head unit has one, but I doubt it has more than bass, treble, etc... Unless you get the DQ61...you just gotta do some research and read on it and find out which one will best fit your needs.....
If you want to improve the overall sq I would go with a processor....JL, RF, Audison, Audiocontrol, Precision Power, Soundstream....
  • Who's Online   0 Members, 0 Anonymous, 483 Guests (See full list)
