slowfkncar Posted August 24, 2014 Report Posted August 24, 2014 the grounds ain't loose! even took the ground from the 1400.1 which has no issues and shoved it in the 60.4... same issue. it's the amp. i took a rc cable with a 3.5m jack and used my phone. as soon as i put it in channel 1&2 it went into pro. tried with ch 3&4 and all was fine until my car was turned on 14v then it would cut in and out of pro... I'm pissed! there's not words for how pissed i am. i did everything right.when i swapped grounds everything was disconnected from both bats. i mean I've only done this idk 200+ times! now I'm without music. i Just cant catch a break. i know people are gonna rag on ct... this time theres not much i can say Nothing wrong with CT. Unfortunately this inevitably happens to all amps. Anyways before you swap the amps, check the speakers by dissconecting one by one. Dont use a DMM because it will only check resting resistance.
Aj11 Posted August 25, 2014 Author Report Posted August 25, 2014 it's not that man. even my phone threw the 3.5m jack puts it in pro. as soon as a rc touches it it goes into pro. even with the speaker wire discontected which i pulled everyone and checked every square inch of it still goes into pro! just now nothing but power ground and rem ... pro! won't mention how my second 1400.1 lasted 4months before it went back for a warranty issue. Then ups destroyed it.. still waiting on.that! jvc deck stinger 1800 front hc 2000 kinetic rear 2 runs of 1/0g big 3/4 ct 60.4 2 ct 1400.1 ct EXO 15 d1 lots of deadner type r comps front stage 6 kicker tweets rear stage lots of great stuff coming soon ho alt more bats ct comps for front stage more deadner sweet amp rack lots of L.E.D lights new deck (thinking 80 prs, or flip out)
Aj11 Posted August 25, 2014 Author Report Posted August 25, 2014 i talked to my ct rep. the problem is being handled better then.i Could have dreamed! even tho I'm not happy with the gear right Now the cs has been Bar none! thats why i love the comp ( maybe not always the product) but my rep there cs... nothing but love! thAnk you!. jvc deck stinger 1800 front hc 2000 kinetic rear 2 runs of 1/0g big 3/4 ct 60.4 2 ct 1400.1 ct EXO 15 d1 lots of deadner type r comps front stage 6 kicker tweets rear stage lots of great stuff coming soon ho alt more bats ct comps for front stage more deadner sweet amp rack lots of L.E.D lights new deck (thinking 80 prs, or flip out)
Broke_Audio_Addict Posted August 25, 2014 Report Posted August 25, 2014 the grounds ain't loose! even took the ground from the 1400.1 which has no issues and shoved it in the 60.4... same issue. it's the amp. i took a rc cable with a 3.5m jack and used my phone. as soon as i put it in channel 1&2 it went into pro. tried with ch 3&4 and all was fine until my car was turned on 14v then it would cut in and out of pro... I'm pissed! there's not words for how pissed i am. i did everything right.when i swapped grounds everything was disconnected from both bats. i mean I've only done this idk 200+ times! now I'm without music. i Just cant catch a break. i know people are gonna rag on ct... this time theres not much i can say Nothing wrong with CT. Unfortunately this inevitably happens to all amps. Anyways before you swap the amps, check the speakers by dissconecting one by one. Dont use a DMM because it will only check resting resistance. So you're saying all amps take a shit at some point? I hope not because that couldn't be further from the truth. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
slowfkncar Posted August 25, 2014 Report Posted August 25, 2014 the grounds ain't loose! even took the ground from the 1400.1 which has no issues and shoved it in the 60.4... same issue. it's the amp. i took a rc cable with a 3.5m jack and used my phone. as soon as i put it in channel 1&2 it went into pro. tried with ch 3&4 and all was fine until my car was turned on 14v then it would cut in and out of pro... I'm pissed! there's not words for how pissed i am. i did everything right.when i swapped grounds everything was disconnected from both bats. i mean I've only done this idk 200+ times! now I'm without music. i Just cant catch a break. i know people are gonna rag on ct... this time theres not much i can say Nothing wrong with CT. Unfortunately this inevitably happens to all amps. Anyways before you swap the amps, check the speakers by dissconecting one by one. Dont use a DMM because it will only check resting resistance. So you're saying all amps take a shit at some point? I hope not because that couldn't be further from the truth. Somewhat yes, just as inevitable as an unleaded fueled engine taking a shit sometime in its life. Hot transistors dont last forever in my experience. Not trying to sound wise here, but I am NOT saying they can't be taken care of to further lifespan.
Aj11 Posted August 25, 2014 Author Report Posted August 25, 2014 a 8 month life span? all i did was upgrade from cca to ofc and replace $6 rca with $40 rca. all bats were disconnected. did that with both amps. there's no reason it should have went. I've done this well over 200 times and this is the first issue I've ever had people here know me as a ct nuthugger which i still am. but I'm not happy at the moment. although the amp well be replaced vary fast and i couldn't be happier with the way it was handled. still very annoying i spent over 12hours pulling ever wire and checking inch by inch, ground after ground thinking i did something wrong. when it turns out it wasnt me at all. I've installed Amps that were well Over 10 years old and are still playing to this day. i don't Blame ct or there reps. shit happens..Just always seems to happen to me! jvc deck stinger 1800 front hc 2000 kinetic rear 2 runs of 1/0g big 3/4 ct 60.4 2 ct 1400.1 ct EXO 15 d1 lots of deadner type r comps front stage 6 kicker tweets rear stage lots of great stuff coming soon ho alt more bats ct comps for front stage more deadner sweet amp rack lots of L.E.D lights new deck (thinking 80 prs, or flip out)
