my first big build 3 15 sp4s on ampere 8.0 TFE 4th order blow through 06 avalanche
I'm talking about the screws on the back of that amp that hold the back piece of the amp on that covers the board. Not amp mounting screws
yep, thats probably were its coming from.Is elevated about an inch,so the fan can breath,and stops when i put my hand under there. I thought mounting amps,and vibrations was a myth? maybe i read it wrong.
I wouldnt say its a myth, blame it more on that amp back plate and screws holding it together being the weakest part of the amp. I had problems with those same screws on my 1200 watt setup when attached to the box raised a little to accomodate for air flow. Some of us open our amps to look at guts, already reducing the thread where those screws dig into. No matter how hard i tightened them i had the same problem until i put some small foam strips between amp and box. Never had a problem with the amp itself for years mounted on an enclosure. Just my .02
Nav-TV Zen V Audio Interface
AudioControl DM-608
(2) Stevens Audio Neo-Comp Full-Size Horns
(4) Faital Pro 6PR160 6.5"
AudioControl LC-6.1200
(1) Fi Neo 4.7 15" D2 in 3.74 Cubic Feet @ 27.70 Hz
Ampere Audio AA3800.1
Odyssey ODP-AGM48 Battery (Starting)
Odyssey ODX-AGM31 Battery (Trunk)
Big 3 - 2\0 Welding Cable, KnuKonceptz Speaker Wire & 1/0 Power Cable, NVX RCAs, Second Skin (Speaker Tweaker Pads, Damplifier Pro Mat), Diode Dynamics LEDs
  • 1 month later...
I sealed up the leaky port a few weeks ago. been bored waiting on amps to come.rounded the corners also, to see if it helps.6F64EEEE-B321-411A-8E7A-CE18E57A8F0D_zps
got some high fidelity rca from dphz , and a custom distribution block for up front. Still working on finding that engine noise.080CF627-CCB2-4E76-AE1D-04E07EC53929_zps
I got a temporary amp for the subs cause i couldn't take being without bass anymore. its only 600 rms, i didn't expect much out of it.CE72D55F-B4D6-40F3-BA00-46A26B9F3129_zps
This is a picture of the dc 9k, i blew one of the mosfets. could have been from vibration,or that i was wired low. Im going to add some outside bracing to the box when it warms up, and i won't be wiring that low again.F9C6007C-0460-417C-B6F8-C15D6F6558BF_zps
How low were you wired?
wired at .37 voltage never dropped below 13.8,and the amp never even got warm. i think there was to much vibration, there was 5 screws missing off the bottom of the amp. also it went out while not even playing music, just popped when i started the truck one morning.
