alaskanzx5 Posted August 30, 2014 Report Posted August 30, 2014 With those ports you will be under 90" of port. You want to be up in the 150-200" range imo. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
heightzbest562 Posted August 31, 2014 Author Report Posted August 31, 2014 With those ports you will be under 90" of port. You want to be up in the 150-200" range imo. what about 4 6" ports
Hugh G. Rection Posted August 31, 2014 Report Posted August 31, 2014 With those ports you will be under 90" of port. You want to be up in the 150-200" range imo. what about 4 6" ports you know better than we do Owner of BigAss Ports
Triticum Agricolam Posted August 31, 2014 Report Posted August 31, 2014 what about 4 6" ports Four 6" ports is about 120 sq in of area, you need close to 200". You have over $3K in subs and amps, why are you so determined to severely handicap your performance by not using enough port? "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Hugh G. Rection Posted August 31, 2014 Report Posted August 31, 2014 what about 4 6" portsFour 6" ports is about 120 sq in of area, you need close to 200". You have over $3K in subs and amps, why are you so determined to severely handicap your performance by not using enough port? He won't listen to our suggestions anyway. Owner of BigAss Ports
RainStryke Posted August 31, 2014 Report Posted August 31, 2014 Here is a good box calculator for pretty much anything you would need. http://www.the12volt.com/caraudio/boxcalcs.asp I mainly use it for the port tuning.
Ritch40 Posted September 1, 2014 Report Posted September 1, 2014 can you imagine the port velocities he is going to see using such a small amount of port area????.....all i can say is ouch
