box dimensions
What subs, what power? I'm assuming you mean 12 cubes net right, after sub displacement and the volume those ports are taking up? What calculator did you use to arrive at that length for 32hz?
2015 Toyota Tacoma Build Thread
2007 Mazda 3; 5000K HID's, Kenwood Excelon KDC-X997, Infinity Reference 6.5 comps in front and coaxials in the rear doors, JL 320.4 four channel, Rab Designs built ported enclosure with an SA12, Kenwood monoblock, Redline Leater shift boot/e-brake boot/center console cover, JBR short shifter/shifter bushings/rear motor mount.
Build Thread
1996 Mazda Miata: Kenwood Excelon HU, Alpine speaker in the doors, Clearwater (miata specific) headrest speakers.
1994 Mazda Protege: Kenwood Excelon HU, Infinity Reference 2 ways all around, 2x RF Punch 10's in ported boxes.
Not knowing the subs no one can help.
Based on it being for 2 18s you need a lot more port area. Something like 2 8" ports maybe even 10" ports.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Correct 11.95 cubes after displacement
Like 5 6" flared round ports 26.5 long each for a 12net@32Hz, and that would likely still be rather sub par.
Ima jus go with 3 6" 15" long ports both ends flared
Why the hell did you ask us then?
Owner of BigAss Ports
You need like 2 times as much port
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
i decided after i asked i wasnt getting much replies anyways
  • Who's Online   1 Member, 0 Anonymous, 5384 Guests (See full list)
