BassDragon Posted August 28, 2014 Report Posted August 28, 2014 Doing my install right now and I have a couple questions. Here's what I have - Two DC Lvl 2 12"s, 1.2k, SHCA 1/0 amp & big 3 kits, two 350a fuses, one 250a, XS 3400, stock alternator (60 some amps). 1. For the remote turn on, there is no wire on my harness for accessory or anything else. Could I just wire it in with the "12 volts Switched Power"? It's a Kenwood KDC108. 2. When is the big 3 necessary? I'm probably not going to be able to finish tonight but I'd like to pre-wire everything. I can get the amp ready with the 250 fuse and leave the big 3 to see if I absolutely need it. 3. I know there's a third... I'll update when I think of it TIA ---------------------------------------------- CURRENT PROBLEM: Trying to get two D4 DC level 2 12"s subs to 1 ohm on a DC 1.2k. Currently at ~1.8 ohm final. Coils are about 4.4 each. When I start to play music (to set gains), the ohm load boosts to over 20. 1993 Toyota Tercel Two DC Audio Lvl 2 12'sDC 1.2k
evermaxx Posted August 28, 2014 Report Posted August 28, 2014 1. yes 2. no its not, but it is suggested. Team Subsonic Lows Get your garbage EMF products of my amp bitch Man....it makes a nice work bench
BassDragon Posted August 28, 2014 Author Report Posted August 28, 2014 Also, which one goes where? 1993 Toyota Tercel Two DC Audio Lvl 2 12'sDC 1.2k
SIDE SHOW Posted August 29, 2014 Report Posted August 29, 2014 Make the blue lead the right and the black the left
BassDragon Posted August 30, 2014 Author Report Posted August 30, 2014 So I used this diagram to wire my subs but the outcome was 2 ohm not 1. I just checked again and all the wires are in the right place. Any idea why? 1993 Toyota Tercel Two DC Audio Lvl 2 12'sDC 1.2k
BassDragon Posted August 30, 2014 Author Report Posted August 30, 2014 I just tried the crutchfield diagram and it came out to ~1.8, 1.7 ohm. The 1.2k is 1200w at 1ohm. How much of a difference wil it be if I use it how it is? 1993 Toyota Tercel Two DC Audio Lvl 2 12'sDC 1.2k
Chris Hammer Posted August 30, 2014 Report Posted August 30, 2014 What are the coils on teh subs? MY BUILD *****http://tinyurl.com/gmcbuild***** Vehicles 2005 GMC Canyon CB1000r - Currently where any future funds are going. (exhasut,bazzaz, ohlins shock, screen, etc.) crf250r - Used to be race bike..now I just trail ride..practice at the track on it. CH80 - Daily beater (when nice weather)best 150$ ever spent. 100+mpg Sold to: Skullz - pstone11 - Leo1103 - Volvo 63' - pavelpardo - imnew59585 Shower farts still piss me off.I think theyre pretty neat. When the water runs down your crack as you let one out... its like shitting in a crockpot.
BassDragon Posted August 30, 2014 Author Report Posted August 30, 2014 What are the coils on teh subs? Dual 4. Just checked them and they're doing about 4.4 each 1993 Toyota Tercel Two DC Audio Lvl 2 12'sDC 1.2k
BassDragon Posted August 30, 2014 Author Report Posted August 30, 2014 Updated original post with problem 1993 Toyota Tercel Two DC Audio Lvl 2 12'sDC 1.2k
reedal Posted August 31, 2014 Report Posted August 31, 2014 if you measured them at 4.4ohm each, and wired them correctly, then you should be at a 1.1ohm resistance reading. parallel resistance is calculated for all four voice coils (two per sub) by: Resistance Total = 1/ (1/r1 + 1/r2 + 1/r3+ 1/r4) r1 thru r4 being the resistance of each voice coil so if you're not getting the correct resistance when wired, then you either wired it wrong, or you may have a open in a wire. check the resistance of each piece of wire. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
