Any thing I should tweak on this box?
The sub I will be using is a soundqubed HDS315. And I will be powering it with 750 watts wired to 2 ohms. Will eventually see about 900-1000 watts. Also it will be in a mazda 3. So anything you guys think I should change let me know. Thanks:D
So you're going to put a 15" woofer into 1.75 cubes, then tune to 34hz with 25" port area?
Why not check out the SQ website and use recommended specs for that woofer.
I have a HDS312 in a 2.25 cubic feet box tuned to 34Hz and it sounds great. A 15 is going to need about 4 cubic feet atleast... their website recommends a 5 cubic feet design.
box is way to small. my hdc 3 12 is in a 2.5 cube box. SQ likes big boxes you will want to run AT LEAST 3cubes but 4 would bbe better i think
use this to help
http://www.soundqubed.com/Box-Sizes-and-Tuning-_ep_68.html
Edit: pluse you will need atleast 17in in higth if you plan to mount the woofer facing foward or too the rear.
IMO i would do 18in tall 35in wide and 18
with port about 16.5in tall X 3in wide by 15in long.
this should give you about 50in2 of port and tuning close to 37
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
rainstryke you from the evga forums?
use this to help
Thanks for the input I will have to go remeasure and see whats the biggest I can do it.
If anything, the listed sub displacement will be in the ballpark.. if you want a small box get some nice 12".
use this to help
Yep
  • 3 weeks later...
  • Who's Online   0 Members, 0 Anonymous, 2987 Guests (See full list)
