DJ JDub Posted August 30, 2014 Report Posted August 30, 2014 When choosing an amp, should you go with exactly what you need (say you have two subs that are 600RMS a piece) Would you go with a 1200RMS amp or go with a 1500 RMS amp to power them?
Broke_Audio_Addict Posted August 30, 2014 Report Posted August 30, 2014 I would get the 1500 rms amp and have some headroom. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
RainStryke Posted August 30, 2014 Report Posted August 30, 2014 Headroom is nice and allows you to have the option for more power if it's needed in the future. If you buy a quality amplifier, it shouldn't get hot under full load. I currently have a 1700w amplifier powering a 1200w sub and I have to be mindful of my power settings, because I can melt my voice coil if I push it more than 50%. But the nice thing is, it gave me headroom for a second sub, so now i'll be able to push my amplifier to it's full capability and I don't have to worry about destroying my equipment. You should also do your research before you purchase an amplifier. There are many amplifiers out there that push more than they are rated. Like the crescendo S1500.1 can push almost 1900w in dynamic RMS.
Broke_Audio_Addict Posted August 30, 2014 Report Posted August 30, 2014 Nevermind. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
RainStryke Posted August 30, 2014 Report Posted August 30, 2014 That's your definition of headroom... What if the amplifier pushes 1700w @ 1OHM but it can go down to .8OHM's and push 2200w, showing more potential. There are a lot more factor's involved when your amplifier is capable of more than it's rated and does not heat up when at it's intended rated power by the manufacture. That's why you don't buy a crap amplifier.
Broke_Audio_Addict Posted August 31, 2014 Report Posted August 31, 2014 There is no your definition or my definition for headroom it is one definition and that's it. http://www.crownaudio.com/how_much_power.htm That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
REH Posted August 31, 2014 Report Posted August 31, 2014 That's your definition of headroom... What if the amplifier pushes 1700w @ 1OHM but it can go down to .8OHM's and push 2200w, showing more potential. There are a lot more factor's involved when your amplifier is capable of more than it's rated and does not heat up when at it's intended rated power by the manufacture. That's why you don't buy a crap amplifier. Show me an amp that does 1700@1 and [email protected] Headroom is nice and allows you to have the option for more power if it's needed in the future. If you buy a quality amplifier, it shouldn't get hot under full load. I currently have a 1700w amplifier powering a 1200w sub and I have to be mindful of my power settings, because I can melt my voice coil if I push it more than 50%. But the nice thing is, it gave me headroom for a second sub, so now i'll be able to push my amplifier to it's full capability and I don't have to worry about destroying my equipment. You should also do your research before you purchase an amplifier. There are many amplifiers out there that push more than they are rated. Like the crescendo S1500.1 can push almost 1900w in dynamic RMS. What are you even talking about? You can melt your coils if you give them 50% clean power? What?
SIDE SHOW Posted September 1, 2014 Report Posted September 1, 2014 Most subs die due to underpowering/clipping..... headroom is always better imo
RainStryke Posted September 1, 2014 Report Posted September 1, 2014 That's your definition of headroom... What if the amplifier pushes 1700w @ 1OHM but it can go down to .8OHM's and push 2200w, showing more potential. There are a lot more factor's involved when your amplifier is capable of more than it's rated and does not heat up when at it's intended rated power by the manufacture. That's why you don't buy a crap amplifier. Show me an amp that does 1700@1 and [email protected] Headroom is nice and allows you to have the option for more power if it's needed in the future. If you buy a quality amplifier, it shouldn't get hot under full load. I currently have a 1700w amplifier powering a 1200w sub and I have to be mindful of my power settings, because I can melt my voice coil if I push it more than 50%. But the nice thing is, it gave me headroom for a second sub, so now i'll be able to push my amplifier to it's full capability and I don't have to worry about destroying my equipment. You should also do your research before you purchase an amplifier. There are many amplifiers out there that push more than they are rated. Like the crescendo S1500.1 can push almost 1900w in dynamic RMS. What are you even talking about? You can melt your coils if you give them 50% clean power? What? Here, I was a little off... it does a little over 2,000 @ .8OHM @ 5:13 As for 50%... Yes, if I put my gain @ 50% with the amplifier that is in that video, I can smell my subwoofer if I crank the volume to 75%.
Broke_Audio_Addict Posted September 1, 2014 Report Posted September 1, 2014 That's your definition of headroom... What if the amplifier pushes 1700w @ 1OHM but it can go down to .8OHM's and push 2200w, showing more potential. There are a lot more factor's involved when your amplifier is capable of more than it's rated and does not heat up when at it's intended rated power by the manufacture. That's why you don't buy a crap amplifier.Show me an amp that does 1700@1 and [email protected] Headroom is nice and allows you to have the option for more power if it's needed in the future. If you buy a quality amplifier, it shouldn't get hot under full load. I currently have a 1700w amplifier powering a 1200w sub and I have to be mindful of my power settings, because I can melt my voice coil if I push it more than 50%. But the nice thing is, it gave me headroom for a second sub, so now i'll be able to push my amplifier to it's full capability and I don't have to worry about destroying my equipment. You should also do your research before you purchase an amplifier. There are many amplifiers out there that push more than they are rated. Like the crescendo S1500.1 can push almost 1900w in dynamic RMS. What are you even talking about? You can melt your coils if you give them 50% clean power? What? Here, I was a little off... it does a little over 2,000 @ .8OHM @ 5:13 As for 50%... Yes, if I put my gain @ 50% with the amplifier that is in that video, I can smell my subwoofer if I crank the volume to 75%. So you think your gain at 50% means you are getting %50 of what your amp is capable of outputing? That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
