Is a battery isolator and a busbar the same thing
no
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Not even close a busbar links multiple batteries together an isolator is a relay the opens and closes to seperate batteries from each other when your vehicle is turned off so your starting battery doesn't get drained so you can still start your car. Really the isolator is useless though because you shouldn't be playing with your car off especially to thepoint your voltage is so low your car won't start.
so if I were to put multiple batteries in, you are just saying that it is useless to have
Also should point out that having the isolator can cause harm to your alt if you drained your rear batts to nothing then started your car it would have to charge how ever many dead rear batts you have back up and it wouldn't enjoy that very much.
The isolator yes that's exactly what I'm saying. The bussbar no it is very useful.
thanks man
