Built better box. Almost doubled output! before and after pics!
fufhubbin
Good work man! Nothing beats doing the research, asking questions, and building something that works. I too made the same mistakes converting the design to a cutsheet and pieces came up a little short with the port and the baffle. They only get better from here. :good:
On 6/30/2011 at 1:11 AM, 'Ray' said:
Acoustical energy is free. Electrical energy is not.
i got like 100 + nails from a nail gun so it better be ha thanks
what are the disadvantages of tuning in the mid 20hz.
with that 10" tuning in the 20's will make it just play lower. 10's dont need a higher tune to play high because the cone area is smaller and less weight, so it has tight punchy bass rather a 18 has a large heavy cone. Correct me if im wrong, but thats what i remember someone telling me. thats why you weight passive radiators to get low response.
1997 subaru legacy outback
Four 15's in a almost wall
Rockford Fosgate t2500-1bdcp
Rockford Fosgate T400-4 on tweets
Rockford Fosgate T400-4 on highs
Rockford Fosgate T400-2 on midrange
Rockford Fosgate T400-2 on midbass
Optima Yellow top batteries
270A Singer alt (working on a bracket for a second)
Lots of Second Skin
OP just a little advise, you could get a leak overtime in the shown spot so see if you can do a small fix there:
if OP can get to that area circled i would highly suggest he get busy with some fiberglass just to make certain that area does not become an issue down the road.
resin and some good heavy weight matte on the inside and then some chopped up glass on the outside to make a 45* angle.
id also suggest adding an additional baffle.
it has 2 baffles now. and i reinforced that corner with a 1x1x12 inch piece and nailed it up and put extra glue on it.its hard to see but thats whats behind that corner. its only there cause I made a mistake! lol
ORION HCCA 10.4 2000 watts RMS 4000 watts max
hifonics brutus 2600 bxi
Alpine IDA -305 Digital receiver
0 gauge power wire 250 amp fuse
800 watt BUTTKICKER BASS SHAKER
Kicker zx-400 amp to power buttkicker
why are the port walls all different sizes?
cause i messed up lol do u think it affects the sound. i could still cut pieces that are small and make it flush
Rebuild the box. Take the skills you acquired from this one and apply them to the next. The reason your other box didn't work well was because you had virtually NO port area. What you had was basically a leaky sealed box.
i probly will rebuild it. but im thinking of tuning lower. it sounds good at 34 hz but what if i did 28hz. would theres be any pro and cons to tuning 28hz for the 10inch orion with as FS of 44hz
  • Who's Online   0 Members, 0 Anonymous, 4973 Guests (See full list)
