09 Duramax 2500 HD Walled. NSv3 18's on a NS1
Okay guys, Im making this build log for a new friend of mine that i did a walled build on his truck. This build is done already, and will have additions but this build log at this point will have a full start to finish UNSEALED wall build.
Basically this is a 2009 chevy 2500hd with the 6.6 duramax. He brought it into a local shop named Audio Outlet in san marcos texas where i was recruited to do his whole build after they seen my car.
The equipment being used is as follows
JVC double din
Sundown SA components
Sundown 100.4 v2
Sundown NS1 v2
1 singer 320 small case hairpin
2 Sundown NSv3 18's
2 xs power d4800's
2 xs power d3100's
TONS of stinger wire and gear
a few other goodies also.
The goal of this build was to make a clean and loud wall where there was leg room but it couldn't take away from the truck.
SO LETS GET STARTED!
This is how i found the truck. With the 2nd alternator installed, the small deadening done, and the components installed. THATS IT! So here are some first pictures i took of it. First thing i did was get some runs of cable in there.
2 runs positive 2 runs negative of stinger 1/0
YAY... running cable
A little later.
Skipped a few hours later and all the wires are run and taped down.
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
d3100s lookin sexy
LC1 bass knob tucked away nicely :)
Getting this front fuse block all done. Peep the sky high cutters ;)
Now we move on to the box.... This thing was a disaster when i got there, but i quickly changed that.
5.75 cubes per 18, 15.14 sq inches of port per cube tuned to about 32hz. Top port. Much MUCH MUCH better then when i got there. It was 8 cubes per, 3.45 sq inches of port per cube tuned to 41. (they had horrible calculations) And it was center ported. I don't have pics of it. But i fiberglassed the center port shut and made this thing a bad ass top ported wall.
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
what is the other alt?
are you doing the ONE stock for 12 and SINGER for high or?
Stock alt and a singer. The customer is getting a second singer soon.
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
also
when landing the wire,,.. it is a great time to use a strip of deadener
No deadener was left when they were done. Things had to be done the best way i could. Trust me, i turned this build from a huge failure into a great success. Enjoy the build log. 70 more pics coming now.
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
My buddy david came from houston to help me build this box. Couldn't have done it with out his help.
Here are a bunch more pics.
The first of MUCH bracing.
Mock up...
Resin to smooth out the port
Sanding begins.
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
i like the box!
1997 subaru legacy outback
Four 15's in a almost wall
Rockford Fosgate t2500-1bdcp
Rockford Fosgate T400-4 on tweets
Rockford Fosgate T400-4 on highs
Rockford Fosgate T400-2 on midrange
Rockford Fosgate T400-2 on midbass
Optima Yellow top batteries
270A Singer alt (working on a bracket for a second)
Lots of Second Skin
Primer mock up.. We did about 5 layers of resin smoothing and sanding with 220 grit.
Bracing..
Bracing.....
20140816_074324_zpsufevk6zu.jpg..
SANDING
Nice and flat. We found some bad spots and decided to sand some of our primer off..
Paint..
Excuse the dust.
IN THE TRUCK!!!
Now it was time to make it look good..
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
SATIN stain... Looks much darker in this pic then it was.
Side bottom beauty panel.
Ghetto solution for a roof (my least favorite part of this build. Ill be correcting this when we do the seal off)
Stain... yum.
Almost looks like furniture
Getting it all in place.
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
