KenC210 Posted September 15, 2014 Report Share Posted September 15, 2014 So I am ready to set up the gains in my truck with the DD-1. How exactly would I do with the OEM radio? I will also set the levels to my Audiocontrol LC7i. I am wanting to get max volume from the factory deck then adjust gain levels on the LC7i. Kids Cadi Power Wheel Build2007 Ford Escape Build2012 Toyota Corolla Build 2013 Toyota Tundra Link to comment Share on other sites More sharing options...
audiofanaticz Posted September 15, 2014 Report Share Posted September 15, 2014 You do it the same way as you would normally. Im assuming your using high level inputs, so you would check those speaker wires that your using as input with 0db. Then follow the standard steps from the lc7 to the amp(s). Link to comment Share on other sites More sharing options...
KenC210 Posted September 15, 2014 Author Report Share Posted September 15, 2014 You do it the same way as you would normally. Im assuming your using high level inputs, so you would check those speaker wires that your using as input with 0db. Then follow the standard steps from the lc7 to the amp(s). Thank you, That is kinda what I assumed but was not very sure. Kids Cadi Power Wheel Build2007 Ford Escape Build2012 Toyota Corolla Build 2013 Toyota Tundra Link to comment Share on other sites More sharing options...
philrab Posted September 15, 2014 Report Share Posted September 15, 2014 You do it the same way as you would normally. Im assuming your using high level inputs, so you would check those speaker wires that your using as input with 0db. Then follow the standard steps from the lc7 to the amp(s). Thank you, That is kinda what I assumed but was not very sure. Just remember to start upstream and work your way down. Forget or skip over a piece of equipment, and that'll be where the distortion comes from. 2015 Toyota Tacoma Build Thread 2007 Mazda 3; 5000K HID's, Kenwood Excelon KDC-X997, Infinity Reference 6.5 comps in front and coaxials in the rear doors, JL 320.4 four channel, Rab Designs built ported enclosure with an SA12, Kenwood monoblock, Redline Leater shift boot/e-brake boot/center console cover, JBR short shifter/shifter bushings/rear motor mount. Build Thread 1996 Mazda Miata: Kenwood Excelon HU, Alpine speaker in the doors, Clearwater (miata specific) headrest speakers. 1994 Mazda Protege: Kenwood Excelon HU, Infinity Reference 2 ways all around, 2x RF Punch 10's in ported boxes. Link to comment Share on other sites More sharing options...
