A lot of people told me two 18's wouldnt fit in my trunk. Still did it and its turing out pretty good, But if it fucks up i'll be a man and post how i fucked up. Nothings impossible, sure, you can get four 12's in your trunk, but how will it sound? If you do go though with it, post videos and updates, Even if your wrong.
1997 subaru legacy outback
Four 15's in a almost wall
Rockford Fosgate t2500-1bdcp
Rockford Fosgate T400-4 on tweets
Rockford Fosgate T400-4 on highs
Rockford Fosgate T400-2 on midrange
Rockford Fosgate T400-2 on midbass
Optima Yellow top batteries
270A Singer alt (working on a bracket for a second)
Lots of Second Skin
i will continue posting either way because im learning just like everyone else but im gunna go for an isobaric box
1 dc level 5 15
t2500-1bd
Rockford 10 farad hybrid capacitor
4 rockford pro punch mids
2 pro punch super tweeters
Both on pro punch rockford crossovers
T400-4 (speaker amp)
30ft sky high 1/0
20 ft rockford 1/0
xs d3400
xs d1200
stock batt under hood
200 sqft fat mat
kenwood kvt-516 flip-out
and 70ft Sky high 14gauge speaker wire
when you do isobaric you do a push pull polarity setup so when one pushes out the other moves with it... if you wire it so they fight they would cancel out.... just thought I would mention this since no body answered your question.... taking others trial and error will help alot with design failures but sometimes you find an anomaly in where it worked for you...still to this day people argue about what way to face a sub in a trunk ive done it every way and depending on how free the air moves the bass curve develops differently.... personally speaking if I was to do a 4 12" setup in a trunk I would look in to either a sealed ported combo or 2 different sized ported boxes one for spl and one for tighter bass.... this way your passband will be wider if you are looking for all around music.... maybe tune one for 28-32hz and one for 35-40hz
how do you wire them so one hits before the other
1 dc level 5 15
t2500-1bd
30ft sky high 1/0
20 ft rockford 1/0
xs d3400
xs d1200
200 sqft fat mat
It's not "one hits before the other" One driver is out of phase, it's wired up backwards to the amplifier.
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
so one's wiring lets just say positive to positive then negative to negative and the other sub is positive to negative and negative to positive?
1 dc level 5 15
t2500-1bd
30ft sky high 1/0
20 ft rockford 1/0
xs d3400
xs d1200
200 sqft fat mat
will i be able to wire them both to the same mono block on the amps at 2 ohm, 2 subs per amp and at 2 ohm. im reading everything about it and still am a little confused.
1 dc level 5 15
t2500-1bd
30ft sky high 1/0
20 ft rockford 1/0
xs d3400
xs d1200
200 sqft fat mat
I can't say without drawing a diagram, but it could get confusing with dual voice coils.
Say if you had two single four ohm woofers...you'd wire one to the amplifier in polarity (+ to + and - to-) and the second in revers (+ to - and - to +) you'll still have a two ohm load, but the reversed woofer is out of phase.
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
Wut.
"Clipping" is the biggest forum boner now. It's like witchcraft... it automatically explains just about everything people don't understand.
My build log: http://www.stevemeadedesigns.com/board/topic/200295-gckless-2011-chevrolet-impala/
High resolution photos: Gilbert Kless Photography
