Speaker cable subwoofer-amplifier
Hi!
My woofer and amplifier can take maximum 8AWG speaker wire.
I dont know how thick wires i should use.
Woofer is RF T2D212 1ohm 1200W RMS
So woofer will be wired internally in parralell over the voice coils.
And then wire to the speaker terminal on my box. From speaker terminal on box to
amplifier. Quite short lengths here. Placing amp on the back of the box where terminal is.
I cant find any bigger speaker wires than ~11AWG (~4mm2) on swedish car audio sites.
is that enough or should i order something else?
Just use some 8 Gauge power wire if you can't find 8 Gauge speaker wire.
I think there will be problems fitting 8AWG to the speaker terminal on the box.
Maybe i can make it work when i solder it. I think the "pins" are quite small on the terminal.
Isnt 11 AWG enough? for those short lengths?
12 or 10 would work just fine but if you really want the 8 I was just giving you another option.
Thanks for advice!
Any downsides of using 11 AWG than 10 or 8 in my case?
I got 11 AWG Supra Jentech Sky 11AWG (4mm2) at home so i was thinking of using that.
But i need some more of that.. so i was thinking of order som more.
I just realized that i cant use 8AWG because woofer terminals wont take two 8AWG cables on one + and - terminals.
from one voice coil + to the other voice coil +
and one voice coil - to other voice coil -
and then from one + to box terminal and one from - to box terminal.
It wont fit.
Any other solutions? or just accept that i should use 11AWG :)
Woofer specifications tells me this:
Speaker Connector Dual 8 AWG slot load
  • Who's Online   0 Members, 0 Anonymous, 3413 Guests (See full list)
