How to build a Self Cooling amp rack (easy) - a quick build using Fans / SMD TM-1
Nice write up Steve. Will help in my build.
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
Looks like the Yukon is getting a little system put in it. ;)
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
  • 11 months later...
  • 6 years later...
3 minutes ago, floridaplur said:
Old thread back to life lol.
What orientation should the fans be? All blowing air in, or half blowing in and half pulling out?
I didn't read this while thread, but I've watched the YouTube videos that Steve has used the fans and it seems he'll put fans on one side blowing in, and the fans on the other end blowing out.
A good one to watch is of the Tahoe. Old ass video when he's first building the under the enclosure amp rack in his garage at home. The way he gets air to flow though the different sections is a really good lesson in my opinion
Edited by Dafaseles
On 9/26/2014 at 5:54 PM, meade916 said:
This week i am tossing together a quick little amp rack to demonstrate just how easy it can be to keep your temperatures under control...and how efficient just a few fans controlled by an SMD TM-1 can be. I literally built this in a couple hours time and that includes going to the store for the fans, drinking my coffee, talking on the phone etc. Cooling is obviously very important to the longevity of your amp. Heat kills. Cool amps live longer. So this isn't the ONLY way to do it, but for those who had no idea, this is just one option.
Now the CFM is something that will come into play. Just use something that moves good air. These are some basic computer case fans. They are cheap and easy to use. The draw almost nothing. The SMD TM-1 can safely run 5a worth of fans directly off the unit without a relay. Matter of fact a relay won't even work so don't try it. Most fans i have seen are under .3a so the unit can run a lot. These fans actually only draw .16a so if i wanted to i could run 31 off of it! For this demo i am only doing 4. As you will see in the video, it was more than enough. The heatgun i was doing to heat up the chamber could not keep up with the fan system....very efficient IMO.
VIDEO IS STILL PROCESSING: it will be here when ready
http://img.photobucket.com/albums/v518/meade916/SMD%20DAmore%20Misc/IMG_5631_zps77e71f7b.jpg
http://img.photobucket.com/albums/v518/meade916/SMD%20DAmore%20Misc/IMG_5632_zps3bbbaf0d.jpg
Available in C or F. They also work GREAT on computer towers!
http://img.photobucket.com/albums/v518/meade916/SMD%20DAmore%20Misc/IMG_5633_zps99eaa89e.jpg
http://img.photobucket.com/albums/v518/meade916/SMD%20DAmore%20Misc/IMG_5634_zps2e8c7550.jpg
http://img.photobucket.com/albums/v518/meade916/SMD%20DAmore%20Misc/IMG_5635_zps087be821.jpg
http://img.photobucket.com/albums/v518/meade916/SMD%20DAmore%20Misc/IMG_5636_zps7f6feab1.jpg
http://img.photobucket.com/albums/v518/meade916/SMD%20DAmore%20Misc/IMG_5638_zps7088c839.jpg
http://img.photobucket.com/albums/v518/meade916/SMD%20DAmore%20Misc/IMG_5642_zps5a2c71f8.jpg
http://img.photobucket.com/albums/v518/meade916/SMD%20DAmore%20Misc/IMG_5647_zpse6739704.jpg
http://img.photobucket.com/albums/v518/meade916/SMD%20DAmore%20Misc/IMG_5648_zps9117a01b.jpg
http://img.photobucket.com/albums/v518/meade916/SMD%20DAmore%20Misc/IMG_5649_zpsde6208ab.jpg
http://img.photobucket.com/albums/v518/meade916/SMD%20DAmore%20Misc/IMG_5655_zpsbb0f8b74.jpg
http://img.photobucket.com/albums/v518/meade916/SMD%20DAmore%20Misc/IMG_5656_zps682084c0.jpg
http://img.photobucket.com/albums/v518/meade916/SMD%20DAmore%20Misc/IMG_5657_zpsbc382dc1.jpg
http://img.photobucket.com/albums/v518/meade916/SMD%20DAmore%20Misc/IMG_5663_zps2b5f3beb.jpg
http://img.photobucket.com/albums/v518/meade916/SMD%20DAmore%20Misc/IMG_5664_zps26642896.jpg
I really like this build and I'm trying to incorporate a very similar build in my own system to keep my amps cool, after purchasing the SMD-TM1 and fans I've run into a slight problem, how do you wire everything?
  • Who's Online   1 Member, 0 Anonymous, 1977 Guests (See full list)
