I just installed an air compressor system on my truck, and i connected the hot wire for the electric solenoid for my air horn to the same battery terminal that my amps are connected to. But, every time i release the horn button for the air horn my speakers make a pop noise. I dont get any noise out of my subs, only from the 4 door speakers. Any ideas why this is happening? Or how to fix it?
Thanks in advance!
How is it all grounded?
How many batteries ??
the solenoid and switch are gounded to the firewall in the engine bay and the amps are grounded to the body in the rear of the cab
and i have one battery in the stock location
Not enough battery power for the compressor ... Let alone the compressor AND amplifiers ...
its a 1000 amp battery and the compressor is only 30 amps, theres enough power, plus i only run either the compressor or my system, not both at once.
and the speakers pop when i press the horn switch which only operates a 12v solenoid.
the speakers pop when the amps are switched on when the ignition is on, when the truck is off theres no pop
The solenoid is a coil of wire that stores energy.
When you release the button the solenoid releases the energy by a large negative spike which can cause "popping" sounds.
Try a 5-10A reversed biased diode directly on the solenoid terminals.
Diode cathode on the positive terminal.
Diode anode on the negative terminal.
Relays have this same issue and some are built with diodes in them.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
Dash mounted O-scope
Highs Amp - PPI Art A404
DC Audio DC9.0K
2- DC Audio XL12m2
JUNE 2014 SOTM WINNER
SOTM BUILD:
thank you! i will try that out when i get some time
  • Who's Online   0 Members, 0 Anonymous, 991 Guests (See full list)
