Jhunt94 Posted September 30, 2014 Report Posted September 30, 2014 Alright so I've finally gotten fed up with it enough to ask. I have a 250a Mechman alternator and an xs d3400 battery for the electrical in my truck. For my amps I have a RF T1500-1bdcp and a T400-4. The first thing is that I feel like my charging voltage is not that strong throughout the day. When I start my truck in the morning (depending on the temperature) I'll have about 14.0-14.3 volts, and as the day goes on depending on how much I start my truck it might get down to 13.1-13.4. Now I don't know if that's normal or not, but I was just going to state that to begin with. The second thing is that I can be playing music and get massive voltage drop. On some bass hits I've seen it go down to low 12's or high 11's. I feel like that with the alternator and battery I have I shouldn't be getting that much voltage drop. So I'm just wondering what you guys think, and if you have any more questions about the setup just ask. 2007 Ford F-150 Reg. Cab. Flareside250 Mechman AlternatorSky High Car Audio Big 3 XS Power D3400Rockford Fosgate 1/0 amp kitRockford Fosgate T1500-1bdcpRockford Fosgate T400-4DC Audio Lvl 4 12"Rockford Fosgate Punch 6.5" componentRockford Fosgate Punch 6x8Pioneer AVH-P2300DVDSMD Volt Meter
TRON Posted September 30, 2014 Report Posted September 30, 2014 You have a smart charging system in you truck no doubt. It's supposed to drop the voltage when the battery doesn't need charging in order to decrease the amount of work the engine has to do to spin the alternator. Same thing happens on my truck, start up at 14.8v and it drops down as low as 12.8v when the batteries are topped off with the charger. The computer is supposed to sense the increased electrical demand to bump the voltage back up, but I found that it didn't work too well. External regulator is your best option to fix that. I have a MLA module, works wonders. Avalanche Alpine Type S comps Alpine Type S 10'' Alpine MPR-F300 Alpine MRX-M50 Mechamn 270 XS Power d3400s
Jhunt94 Posted September 30, 2014 Author Report Posted September 30, 2014 ahhh that sucks, well what about the voltage drop? 2007 Ford F-150 Reg. Cab. Flareside250 Mechman AlternatorSky High Car Audio Big 3 XS Power D3400Rockford Fosgate 1/0 amp kitRockford Fosgate T1500-1bdcpRockford Fosgate T400-4DC Audio Lvl 4 12"Rockford Fosgate Punch 6.5" componentRockford Fosgate Punch 6x8Pioneer AVH-P2300DVDSMD Volt Meter
TRON Posted September 30, 2014 Report Posted September 30, 2014 That could also be the system have a delay in increasing the alternators output, but it shouldn't stay down in the 12s. Are the amplifiers grounded to the frame? Avalanche Alpine Type S comps Alpine Type S 10'' Alpine MPR-F300 Alpine MRX-M50 Mechamn 270 XS Power d3400s
sbg Posted September 30, 2014 Report Posted September 30, 2014 Still don't think he should drop to high 11s with his electrical. I mean I run stock alt(110 amp) and a hc2400 with a 4k amp. And never see 11s 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
TRON Posted September 30, 2014 Report Posted September 30, 2014 No he definitely shouldn't be in the 11s, so I'm guessing there's some bad grounding somewhere. Avalanche Alpine Type S comps Alpine Type S 10'' Alpine MPR-F300 Alpine MRX-M50 Mechamn 270 XS Power d3400s
Jhunt94 Posted September 30, 2014 Author Report Posted September 30, 2014 It doesn't stay down it'll only happen for a second, but I don't think it should be happening, I can check the grounds and see if that's it. And no the amps aren't grounded to the frame, I've just never gotten around to doing it. 2007 Ford F-150 Reg. Cab. Flareside250 Mechman AlternatorSky High Car Audio Big 3 XS Power D3400Rockford Fosgate 1/0 amp kitRockford Fosgate T1500-1bdcpRockford Fosgate T400-4DC Audio Lvl 4 12"Rockford Fosgate Punch 6.5" componentRockford Fosgate Punch 6x8Pioneer AVH-P2300DVDSMD Volt Meter
BassMunky Posted September 30, 2014 Report Posted September 30, 2014 big 3? Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
Jhunt94 Posted October 1, 2014 Author Report Posted October 1, 2014 Yeah, I have the big 3 done with sky high 1/0. 2007 Ford F-150 Reg. Cab. Flareside250 Mechman AlternatorSky High Car Audio Big 3 XS Power D3400Rockford Fosgate 1/0 amp kitRockford Fosgate T1500-1bdcpRockford Fosgate T400-4DC Audio Lvl 4 12"Rockford Fosgate Punch 6.5" componentRockford Fosgate Punch 6x8Pioneer AVH-P2300DVDSMD Volt Meter
SLYentist Posted October 8, 2014 Report Posted October 8, 2014 i smell a grounding issue. increased resistance=decreased voltage=increased current for the same demand. ground your amps as best you can and see if the issue is fixed. Cables and wires almost never fail; the terminations do.
