nathanb5533 Posted October 7, 2014 Report Posted October 7, 2014 Well yesterday I was messing with my gains trying to get them right by ear and herd no distortion but after a few minutes my sub went full excursion and then back to normal and now there's no bass, I checked my subwoofer it's not blown it wasn't not at all no scraping of broken voice cool leads fine, then i chedked my amp and power is no not protect then I checked the amp fuses it has 2 40 amps both fine wires are good and the amp also was not warm at all what could it be? 2006 Pontiac G6 3.5L Pioneer AVH-X5800BHS DVD Receiver Singer 320 amp alternator Crescendo audio hp120 battery Crescendo audio bc3500d Crescendo audio s550/2 Crescendo audio s1100/2 2 Sundown audio zv5 12 Rockford Fosgate 440-4D 5 cubic foot octoport tuned to 35 hz 4 crescendo audio pwx 8s 2 crescendo audio pwx 6.5 4 crescendo audio ft1 super tweeters 2 crescendo audio Symphony coaxial 6x9
Broke_Audio_Addict Posted October 7, 2014 Report Posted October 7, 2014 Ear-o-meter ftw. Check your voice coils with a multi meter if they check out OK swap the amp for something else and see if that solves the problem. Fuses can actually be bad without appearing to be bad. I'd suggest buying a dd-1 or borrowing one from someone to set your gains Don't use your ears to do that anymore. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
never knows best Posted October 7, 2014 Report Posted October 7, 2014 Well yesterday I was messing with my gains trying to get them right by ear and herd no distortion but after a few minutes my sub went full excursion and then back to normal and now there's no bass, I checked my subwoofer it's not blown it wasn't not at all no scraping of broken voice cool leads fine, then i chedked my amp and power is no not protect then I checked the amp fuses it has 2 40 amps both fine wires are good and the amp also was not warm at all what could it be? well there's your problem...
nathanb5533 Posted October 7, 2014 Author Report Posted October 7, 2014 I tested the imp on the sub and it jumps around a lot 2006 Pontiac G6 3.5L Pioneer AVH-X5800BHS DVD Receiver Singer 320 amp alternator Crescendo audio hp120 battery Crescendo audio bc3500d Crescendo audio s550/2 Crescendo audio s1100/2 2 Sundown audio zv5 12 Rockford Fosgate 440-4D 5 cubic foot octoport tuned to 35 hz 4 crescendo audio pwx 8s 2 crescendo audio pwx 6.5 4 crescendo audio ft1 super tweeters 2 crescendo audio Symphony coaxial 6x9
Broke_Audio_Addict Posted October 7, 2014 Report Posted October 7, 2014 If you're making any noises at all its going to move around just try and not touch the probes or make noises till it settles. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
nathanb5533 Posted October 7, 2014 Author Report Posted October 7, 2014 Well now when I try to read the imp it shows nothing 2006 Pontiac G6 3.5L Pioneer AVH-X5800BHS DVD Receiver Singer 320 amp alternator Crescendo audio hp120 battery Crescendo audio bc3500d Crescendo audio s550/2 Crescendo audio s1100/2 2 Sundown audio zv5 12 Rockford Fosgate 440-4D 5 cubic foot octoport tuned to 35 hz 4 crescendo audio pwx 8s 2 crescendo audio pwx 6.5 4 crescendo audio ft1 super tweeters 2 crescendo audio Symphony coaxial 6x9
nathanb5533 Posted October 7, 2014 Author Report Posted October 7, 2014 Well no my mm sucks cause I hooked it up to another amp and it works sooo 2006 Pontiac G6 3.5L Pioneer AVH-X5800BHS DVD Receiver Singer 320 amp alternator Crescendo audio hp120 battery Crescendo audio bc3500d Crescendo audio s550/2 Crescendo audio s1100/2 2 Sundown audio zv5 12 Rockford Fosgate 440-4D 5 cubic foot octoport tuned to 35 hz 4 crescendo audio pwx 8s 2 crescendo audio pwx 6.5 4 crescendo audio ft1 super tweeters 2 crescendo audio Symphony coaxial 6x9
nathanb5533 Posted October 9, 2014 Author Report Posted October 9, 2014 Both amp and sub are working i must of changed it from low pass to full range on my amp because after i put it back they both work 2006 Pontiac G6 3.5L Pioneer AVH-X5800BHS DVD Receiver Singer 320 amp alternator Crescendo audio hp120 battery Crescendo audio bc3500d Crescendo audio s550/2 Crescendo audio s1100/2 2 Sundown audio zv5 12 Rockford Fosgate 440-4D 5 cubic foot octoport tuned to 35 hz 4 crescendo audio pwx 8s 2 crescendo audio pwx 6.5 4 crescendo audio ft1 super tweeters 2 crescendo audio Symphony coaxial 6x9
ll_wwcnd_ll Posted October 9, 2014 Report Posted October 9, 2014 Like Broke_Audio_Addict said get a DD-1 or and Oscope and set the gains correctly it will save you the headaches in the long run and will allow you to get more clean power out of your system without toasting everything. As for the weird readings on the subs like Broke_Audio_Addict said literally any noise at all will cause the subs impedance to fluctuate. 2007 4.2L Chevy Trailblazer Crossfire Build6 Crossfire xs v2 15s3 Crossfire 8ks4 Crossfire 6.5 Loudspeakers 2 Crossfire ST-1 Super Tweets 1 Pair of Rockford Fosgate T2 5.25 Components 1 Crossfire C5 800.2 1 Crossfire 400.2's7 XS Power xp3000s 6 C&D Batteries3 Singer Alts 6 Runs of 1/0 OFC (Sky High and Welding Wire)SMD VM-1SMD OM-1Pioneer AVH-p4800BSBuild Log4th Order BL - http://www.stevemeadedesigns.com/board/topic/189896-4th-order-crossfire-trailblazer-buildlog/ Flat Wall BL - http://www.stevemeadedesigns.com/board/topic/198087-2007-42l-chevy-trailblazer-flat-wall-rebuild-build-log-4-crossfire-xsv2-15s-2-crossfire-8ks-xs-power-batts-singer-alts/ScoresMECA - 159.2 @ 37hzUSACI - 161.2 @ 47hzIASCA - 157.9 @ 47hz
