SIDE SHOW Posted October 17, 2014 Report Posted October 17, 2014 the pico fuse is inside the headunit not at the back
islandpride684 Posted October 17, 2014 Report Posted October 17, 2014 im just gonna go with we will find out the issue when i send my headunit in for repair if it works after then great if not then ill solve it thenYou probably blew the pico fuse on the headunit...so my guess is that and the way to fix it is to ground the rca connections in the back of the head unit, or solder the two points on the pico fuse together or send it in and a get a new one...pioneer head units are known for that... no i checked the fuse It's on the inside of the head unit not the ones on the outside Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410
_paralyzed_ Posted October 17, 2014 Report Posted October 17, 2014 If you do this and it goes away it is definitely the pico fuse. You can send it in if the pico fuse is blown and get the pico fuse fixed if you want, but lots of people just do this and the problem goes away and never get the pico fuse replaced.
nathanb5533 Posted October 17, 2014 Author Report Posted October 17, 2014 If you do this and it goes away it is definitely the pico fuse. You can send it in if the pico fuse is blown and get the pico fuse fixed if you want, but lots of people just do this and the problem goes away and never get the pico fuse replaced. i cant see the photo on my work pc 2006 Pontiac G6 3.5L Pioneer AVH-X5800BHS DVD Receiver Singer 320 amp alternator Crescendo audio hp120 battery Crescendo audio bc3500d Crescendo audio s550/2 Crescendo audio s1100/2 2 Sundown audio zv5 12 Rockford Fosgate 440-4D 5 cubic foot octoport tuned to 35 hz 4 crescendo audio pwx 8s 2 crescendo audio pwx 6.5 4 crescendo audio ft1 super tweeters 2 crescendo audio Symphony coaxial 6x9
nathanb5533 Posted October 17, 2014 Author Report Posted October 17, 2014 If you do this and it goes away it is definitely the pico fuse. You can send it in if the pico fuse is blown and get the pico fuse fixed if you want, but lots of people just do this and the problem goes away and never get the pico fuse replaced. i cant see the photo on my work pc since its under warranty im not gonna do that because it may void the warranty 2006 Pontiac G6 3.5L Pioneer AVH-X5800BHS DVD Receiver Singer 320 amp alternator Crescendo audio hp120 battery Crescendo audio bc3500d Crescendo audio s550/2 Crescendo audio s1100/2 2 Sundown audio zv5 12 Rockford Fosgate 440-4D 5 cubic foot octoport tuned to 35 hz 4 crescendo audio pwx 8s 2 crescendo audio pwx 6.5 4 crescendo audio ft1 super tweeters 2 crescendo audio Symphony coaxial 6x9
_paralyzed_ Posted October 17, 2014 Report Posted October 17, 2014 You can undo it before sending it in for warranty and they will never know.
Uriahia Posted October 19, 2014 Report Posted October 19, 2014 had the same problem with my pioneer and it was the pico fuse.
