islandpride684 Posted October 21, 2014 Report Posted October 21, 2014 No pass-thru on the NVXs...i got a diagram ready to go if the OP says what I think he will say...hopefully... Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410
AstoSoup Posted October 21, 2014 Report Posted October 21, 2014 Pass through are nothing more then a built in y adapter. So in essence, there is no such thing as a TRUE 4ch. output on an amp? If a pass through is just a Y adapter, only the first amp will balance/fade, not the second. Head Unit - Clarion VX709 7" DVD Touchscreen Mid/Highs - Front Doors - RF Prime 6.5" component mids. A. Pillars - RF Punch component tweets. B. Pillars - RF Prime component tweets. Rear Doors - RF Punch 5.25" mids. RF Punch 3-way passive X-overs. Mid/Highs Amp - MB Quart Onyx 360.4, 4 channel, 640W RMS. Subs - (2) PowerBass 3XL 15, 1000w RMS, 3" flat wound coil, 562oz motor, 10" spider. Sub Amp - Audiopipe GD6001 @.5ohm, clamped 2825RMS. Box - 9.6 cu^3 net @35Hz, three 6" aero's. Charging - Energizer 120Ah AGM under the hood, MaxLife 75Ah in the rear. Big 3, 140A aftermarket alt. (off brand) Wires - Two JL Audio 2/0ga OFC. runs to rear, 4ga. power/2ga. ground to component amp (OFC), 1/0ga. OFC Knu Konceptz Kolossus Kandy everywhere else.
alaskanzx5 Posted October 21, 2014 Report Posted October 21, 2014 A 4ch amp with pass through would have 4 inputs 2 outputs. 00 front right and left 00 rear right and left 00 pass through right and left. So Eq 00 front out put to highs 00 rear out to 2 y adapters (1 male to 2 female) turning that output into a Left side 0 --> 00 Right side 0 --> 00 So now the rear output has been altered to where it has 2 left and 2 right outputs. Use one set of rear out puts to the mid range Use the other set of out puts to mid bass Use the third output on the amp 00 for Sub(s) Or Eq 00 front 00 rear 00 sub Fro t to highs Rear to midrange pass through from midrange to midbass Sub to sub. Either way the fade effect will only work as I turns the highs down and the kids up when faded to the rear or vice versa the other way around. Left and right speaker separation would still exist. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
AstoSoup Posted October 21, 2014 Report Posted October 21, 2014 A 4ch amp with pass through would have 4 inputs 2 outputs. 00 front right and left 00 rear right and left 00 pass through right and left. So Eq 00 front out put to highs 00 rear out to 2 y adapters (1 male to 2 female) turning that output into a Left side 0 --> 00 Right side 0 --> 00 So now the rear output has been altered to where it has 2 left and 2 right outputs. Use one set of rear out puts to the mid range Use the other set of out puts to mid bass Use the third output on the amp 00 for Sub(s) Or Eq 00 front 00 rear 00 sub Fro t to highs Rear to midrange pass through from midrange to midbass Sub to sub. Either way the fade effect will only work as I turns the highs down and the kids up when faded to the rear or vice versa the other way around. Left and right speaker separation would still exist. First option seems the most logical... You got into that way more than I was about to, props lol. Head Unit - Clarion VX709 7" DVD Touchscreen Mid/Highs - Front Doors - RF Prime 6.5" component mids. A. Pillars - RF Punch component tweets. B. Pillars - RF Prime component tweets. Rear Doors - RF Punch 5.25" mids. RF Punch 3-way passive X-overs. Mid/Highs Amp - MB Quart Onyx 360.4, 4 channel, 640W RMS. Subs - (2) PowerBass 3XL 15, 1000w RMS, 3" flat wound coil, 562oz motor, 10" spider. Sub Amp - Audiopipe GD6001 @.5ohm, clamped 2825RMS. Box - 9.6 cu^3 net @35Hz, three 6" aero's. Charging - Energizer 120Ah AGM under the hood, MaxLife 75Ah in the rear. Big 3, 140A aftermarket alt. (off brand) Wires - Two JL Audio 2/0ga OFC. runs to rear, 4ga. power/2ga. ground to component amp (OFC), 1/0ga. OFC Knu Konceptz Kolossus Kandy everywhere else.
d-nice88 Posted October 21, 2014 Author Report Posted October 21, 2014 Yes indeed that sounds like a good idea but the nvx doesn't have one of those pass thru's and ive looked on sonic electronics and ive only seen one so far that has the power and the pass thru that I need I just dont know if it does rated power is the hifonics x800.4 cuz I was gona wire the speakers like this. First amp to mids and highs second amp with the first 2 chanles for the prv mid bass and bridge the other 2 channles for the 8"woofer so sub amp for the back and 2 4 channels with one for mids highs 2nd for mid bass and other sub for center console and who ever said they had the diagram ready to go can I see it plz thnx alot for yalls input on this its really helping me out
islandpride684 Posted October 21, 2014 Report Posted October 21, 2014 Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410
d-nice88 Posted October 21, 2014 Author Report Posted October 21, 2014 Bah humbug I cant see it on my phone have to wait till I get home :/
d-nice88 Posted October 21, 2014 Author Report Posted October 21, 2014 Ok so I cant achieve this with the nvx amps can I do it with hifonics x800.4
islandpride684 Posted October 22, 2014 Report Posted October 22, 2014 Ok so I cant achieve this with the nvx amps can I do it with hifonics x800.4 Achieve what? You don't need a pass thru, it's a plus if it comes with it...did you look at the diagram at least... Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410
d-nice88 Posted October 22, 2014 Author Report Posted October 22, 2014 I havent seen it yet I havent made it home yet but would it be easier with a pass thru
