HID Question
Has anyone done this or think it will work?
Can I run an HID set strictly off my own switch? The set will be on a relay with me controlling the relay from a switch in the car. The switch will be a rocker I put in (not factory switch). The HIDs will not be connected to any stock harness or wiring.
Will this work? Do Hids work this way with the given standard relay kits? My question is do they work with the plug not connected to the stock harness?
If this wont work Ill create my own relay and switch for them.
if they're connected to your battery they should work fine. you're basically replacing the headlight switch with your own
what i figured, just not sure if i need to make my own relay or use the HID relay kits
Sure will. Have done it several times.
-Zach-
2010 Toyota Tundra
Full Hybrid Audio SQ
7" BDS on 37's
2000 Ford Expedition
160+ dB Green Turd -SOLD- :(
  • Who's Online   0 Members, 0 Anonymous, 3140 Guests (See full list)
