conbon Posted October 23, 2014 Report Posted October 23, 2014 Okay so what i just got was a rockford 800a2 and a 100z2 and a 1 farad cap. what i was planning on doing was using the rockford 2 farad cap i already have on the 800a2 and the 1 farad i just got on the 100z2. i will also get a kinetic hc600 and run both caps from that, then each cap to the amps like i stated before, and i will put inline fuses where necessary. How does this sound to you guys? What changes should i make or just leave it how it is. NOTE: on the 800a2 i will bridge it and be powering a Sundown SA-12 D2 and on the 100z2 i will be powering 2 kenwood kfc 6x8s 2013 Ford Focus Hatchback SE Kicker CS61234 Kicker 40CS674 Kicker KST25 Sundown Audio SA-12 D2 Rockford Fosgate t1000-1bdcp Rockford Fosgate t400-4 Audio Control LC7i Kinetik HC2000 0/1 Gauge Big 3 Upgrade Beer, babes, and bass.
GSanders17 Posted October 23, 2014 Report Posted October 23, 2014 Throw the caps away and just use the battery.
MaxVolume Posted October 23, 2014 Report Posted October 23, 2014 I say lose the caps, just weighing down your electrical other than that sounds fine, assuming you're also tying the kinetic into the electrical system with similar chemistry primary battery (if its a secondary batt)
conbon Posted October 23, 2014 Author Report Posted October 23, 2014 Throw the caps away and just use the battery. why do you think i should get rid of them? 2013 Ford Focus Hatchback SE Kicker CS61234 Kicker 40CS674 Kicker KST25 Sundown Audio SA-12 D2 Rockford Fosgate t1000-1bdcp Rockford Fosgate t400-4 Audio Control LC7i Kinetik HC2000 0/1 Gauge Big 3 Upgrade Beer, babes, and bass.
GSanders17 Posted October 23, 2014 Report Posted October 23, 2014 Throw the caps away and just use the battery.why do you think i should get rid of them?No need for them. The kinetic should be enough plus those type of caps don't really do anything for you.
SLYentist Posted October 28, 2014 Report Posted October 28, 2014 Even if those are true-rated capacitors, they really don't do much for you except take money out of your pocket. Cables and wires almost never fail; the terminations do.
MADVIBES Posted October 28, 2014 Report Posted October 28, 2014 ok, people need to stop dissing caps. Richard clark does one test and everyone jumps the cap bandwagon. caps have virtually no ESR. Batteries have plenty. Caps are effective much more effective due to recharge rate. at instantaneous release of power. combo of the two is excellent. just saying. there is a reason amplifiers use caps in the power supply to stiffen voltage and not batteries. let the hate begin. DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY. 156.9@26hz 158.0@30hz
SlamminBeats Posted October 28, 2014 Report Posted October 28, 2014 ok, people need to stop dissing caps. Richard clark does one test and everyone jumps the cap bandwagon. caps have virtually no ESR. Batteries have plenty. Caps are effective much more effective due to recharge rate. at instantaneous release of power. combo of the two is excellent. just saying. there is a reason amplifiers use caps in the power supply to stiffen voltage and not batteries. let the hate begin. maxwell caps yes, but boss caps and all that no
GSanders17 Posted October 28, 2014 Report Posted October 28, 2014 Somehow I don't think he was refering to the maxwells.
SlamminBeats Posted October 29, 2014 Report Posted October 29, 2014 Somehow I don't think he was refering to the maxwells. LOL
