wrathchild281 Posted October 26, 2014 Report Posted October 26, 2014 Hey guys for my build here which is a few weeks out from being done, I have a question about where to run my dual volt meters. My original thought was one for each of my sub amps(2x kx2400.1s) up on the center console just to see where the final voltage is being displayed. I just saw a video of a guy running two of his volt meters in the console and he had one for the alt reading and one for his battery reading i assume the one by the amp not sure. Which would you guys recommend as a better option. I also want to mention i have a few other items here that are gonne be ran. From my alt i have a xs vcm then i will run through my kicker front stage which is like an epicenter than i have a kicker kq5 to run in the mix as well as these 2 volt meters. There only cheap stingers but i plan to run them so whats your thoughts? thanks 225 Excessive Amperage Alt. 4 Yellow top batteries Pioneer AVH-6600 Kicker KQ5 2 FI 18 BTL's fully loaded 2 zx 2500.1's 4 ks6.5 coaxials 4 ks5.25 coaxials kx650.4 http://www.cardomain.com/ride/2358078
RooTxBeeR Posted October 26, 2014 Report Posted October 26, 2014 I would say have them off the amps On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5
ROLEXrifleman Posted October 26, 2014 Report Posted October 26, 2014 The answer simply is what voltage do you want to monitor. I have two the first is at the battery in the front the second is at the sub amp. If you have one at the front battery and have done the big 3 then by default you will be seeing what your alt is doing as there should only be a bout 3 feet of cable between the two. the second meter allows for monitoring the input of the 2nd item. the main thing to look for is the difference between the two readings as this will tell you if there is an issue between the two points. Rolex you sicken me. Just let me finish my pie ~ Juice
03silvergt Posted October 26, 2014 Report Posted October 26, 2014 I would put it in the amps. 2017 Chevrolet Silverado LT CC - Will be running 2-3 DC Audion M3 8s, unsure of amp, Mechman 320 amp alt. 2005 Ford F150 - Bagged on 24s, fully shaved, raised bed floor.
wrathchild281 Posted October 26, 2014 Author Report Posted October 26, 2014 ya i like the amps idea because if they are seeing the low voltage then i can monitor better i feel. my vcm will be open and visible and should be an accurate alt reading and i assume the batts would charge at what that displays hopefully. 225 Excessive Amperage Alt. 4 Yellow top batteries Pioneer AVH-6600 Kicker KQ5 2 FI 18 BTL's fully loaded 2 zx 2500.1's 4 ks6.5 coaxials 4 ks5.25 coaxials kx650.4 http://www.cardomain.com/ride/2358078
