Figure port length of a 90° elbow?
chuey_316
I need to use 90° elbows on my ports to get the length needed for my abc boxes tuning. Does anyone how much port length the 90° elbow adds, and/or how to figure it? They are 4" ports btw. Thx in advance.
1999 Blazer
AD-244 Alt (soon to be 2)
HU / Pioneer P7800MP
Sub / RE 18HC
Amp / Shopping for a new one
7.71 cubes 118 sq" port area tuned to 34.9hz
Port length is measured down the center. Measure the inner radius of the elbow, and outer radius, and the average of the two should give you the center.
2015 Toyota Tacoma Build Thread
2007 Mazda 3; 5000K HID's, Kenwood Excelon KDC-X997, Infinity Reference 6.5 comps in front and coaxials in the rear doors, JL 320.4 four channel, Rab Designs built ported enclosure with an SA12, Kenwood monoblock, Redline Leater shift boot/e-brake boot/center console cover, JBR short shifter/shifter bushings/rear motor mount.
Build Thread
1996 Mazda Miata: Kenwood Excelon HU, Alpine speaker in the doors, Clearwater (miata specific) headrest speakers.
1994 Mazda Protege: Kenwood Excelon HU, Infinity Reference 2 ways all around, 2x RF Punch 10's in ported boxes.
Well, the port length is measured down the center of the port..... like this....
Black line is actual port length, so 23.25" + 11.75" = 35" of port length
Red line is length of the inner port wall (most way noobies think it is measured.) This would result in 20.75" + 9.25" = 30" which would give incorrect tuning from what your were desiring.
So, for a tube or circular elbow, you imagine a line floating through the DIRECT center of it.
For you to know the exact length it creates, you need to do some math on your own.
If the 90 degree tube is as small as it could possibly be, the port length of it would be 3.14" (diameter * pi / 4),
but in reality PVC 90 degree tubes are a bit bigger (with a small bend at the short side). But a good estimate would be like 4" or so.
Had thought about putting a cap on each of the straight pieces, and filling them with something like sand. Then adding the elbow and measuring the empty space after the sand fills the elbow. Would that be an accurate way of measuring the added length?
1999 Blazer
Sub / RE 18HC
I'll use the method above. Just curious about the sand method is all. With most boxes the port being a little off is no big deal, but it can dramaticaly alter the performance of an abc box, so anything that gets a closer estimate the better. I do appreciate the info.
1999 Blazer
Sub / RE 18HC
  • Who's Online   0 Members, 0 Anonymous, 1800 Guests (See full list)
