Dan2427 Posted October 29, 2014 Report Posted October 29, 2014 In a grand Cherokee the best you can do is 10.5-11 cubes after displacements, keeping back seats. So even 4 15s won't work ported. Id sell 2 and do subs up port up. I left 8-10 inches from roof line and it got really loud. And could do hair tricks with all windows up. Mine was also two M1 level 5s on 4-5k 2003 GMC Yukon Denali Alpine CDA 117 Redoing Mids/Highs 4 Runs of 1/0 Knukonceptz 2+, 2- 4 Deka 9A31's in back (Stock underhood) 250 amp Alt. AQ20K 2 18" Crossfire XS V.2's 12 cubes 33hz 149sq inches of port!
getuaload Posted October 29, 2014 Author Report Posted October 29, 2014 Thanks dan, do you have any pics or build sheets / measurements of your box. I think I'll go with just 2.
hispls Posted October 29, 2014 Report Posted October 29, 2014 In a grand Cherokee the best you can do is 10.5-11 cubes after displacements, keeping back seats. So even 4 15s won't work ported. Id sell 2 and do subs up port up. I left 8-10 inches from roof line and it got really loud. And could do hair tricks with all windows up. Mine was also two M1 level 5s on 4-5k I'd say these volume specs are pretty consistent with what I've been able to fit. Frankly on that power you'd do better with a single high quality 15" or 18" than trying to cram too much cone area into too little box and then have to settle for sub-optimum port size and placement. Thanks dan, do you have any pics or build sheets / measurements of your box. I think I'll go with just 2. Even B-pillar wall will be cutting it tight on 4 18's in a GC. You should try to trade them all for 1 high quality 15" or 18" woofer. Sub up port towards the side is optimum if you want to keep back seats. I've built dozens of boxes for grand Cherokee, PM me if you have any questions on what has and hasn't worked for me.
Dan2427 Posted October 29, 2014 Report Posted October 29, 2014 PM me your phone number I'll text all the pics and cut sheet. It was a box Decaf designed me! I loved it 2003 GMC Yukon Denali Alpine CDA 117 Redoing Mids/Highs 4 Runs of 1/0 Knukonceptz 2+, 2- 4 Deka 9A31's in back (Stock underhood) 250 amp Alt. AQ20K 2 18" Crossfire XS V.2's 12 cubes 33hz 149sq inches of port!
getuaload Posted October 29, 2014 Author Report Posted October 29, 2014 Thanks for all the input, I put all 4 in and hooked up both 1200.1 to them. Didn't sound bad but was still missing something. I re measured my boxes and doubled checked and my original disign would been ok. But I had to modify them boxes to fit & Lost 1/2 cu ft per sub on bottom box & alittle more on top box. After displacement I only got approx 11.5-12ft total. Not enough even for sealed, I needed 14cuft min so even tho it looks good it was a Wasted build. But I had a idea, pull top 2 subs build a plate with square port and run the 2 bottom subs I'd have around 6 ft before port displacement.
