charging agms?
I have a regular car battery up front that is connected to two Kinetik HC2000 in the spare tire well under sub box. It would be a PITA to get at the Kinetik batteries, So Would i be able to throw the charger on the front battery and charge them all at the same time seeing they are all connected?
Yes, since they are all tied in parallel if you throw the charger on the front it will charge all of them. Just keep in mind, get a fair sized charger as it is going to take a while to charge all of them.
ok guys i bough a charger.. so when charging your batteries do you have to disconnect the front battery from the alternator?
the real question here is how do i go about charging the batteries the safe way. do i have to disconnect anything?
also could you use a charger such as a ctek multi us 7002 to charge a stock battery? i have my stock battery out of my car for a while and was wondering if i could maintain that battery with this same charger that is used for agms. i want to keep the stock battery alive in case i ever want to sell the car i can just throw it in the car without having to give up my xs power battery.
Don't try charging the batteries with the car running. The alternator is essentially a charger in a sense, so having two hooked up with possibly different charging voltages could mess some stuff up. As long as the car is off, the alternator won't be spinning meaning it won't be putting out any voltage, so you'll be fine to have the charger on it.
i have the ctek 25000 and it has saved numerous salvaged batteries that has voltage ranging down to 7 volts. i highly recommend CTEK.
Cables and wires almost never fail; the terminations do.
  • Who's Online   0 Members, 0 Anonymous, 3140 Guests (See full list)
