Aistis Šestakauskas Posted November 1, 2014 Report Share Posted November 1, 2014 Hello everyone. I want to ask how can i connect my dual 2ohm voice coil woofer to amp mcHammer vulcane 2400? Can i use two channels of amp? Link to comment Share on other sites More sharing options...
Hotdog Posted November 1, 2014 Report Share Posted November 1, 2014 Series each sub to 4 ohm then parallel them to 2 ohm bridged at the amp. Like this example (NEW) 2004 F-150 Build Log -->http://www.stevemeadedesigns.com/board/topic/192208-hotdogs-f-150-build-log/ 2003 Mercury Mountaineer Build Log --> http://www.stevemeadedesigns.com/board/topic/114380-hotdogs-2003-mountaineer-build-log-20-removed/page__gopid__1602379#entry1602379 2008 Equinox Build Log --> http://www.stevemead...g/#entry1475764 Link to comment Share on other sites More sharing options...
Aistis Šestakauskas Posted November 1, 2014 Author Report Share Posted November 1, 2014 Yeah, it looks good, but my amp have two channels. So won't it push more power by connecting each coil to another channel? Link to comment Share on other sites More sharing options...
Broke_Audio_Addict Posted November 1, 2014 Report Share Posted November 1, 2014 Can you post pics and maybe specs for the amp? I looked up what you said it is and it seems to be a 4 channel and only 2 ohm stable just want to make sure I found the right amp before trying to help. Also are you running one or two subs? That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals. Link to comment Share on other sites More sharing options...
Hotdog Posted November 1, 2014 Report Share Posted November 1, 2014 Here is the manual for it --> http://www.etc-shop.de/1und1_SHOP/Bilder/ETT/751141/751-141.pdf It is a 4 channel amp. The amp can be bridged at 2 ohm according to manual. your put you wires from subs to the amp where the marking show bridged. You would still have two channel left for something else (NEW) 2004 F-150 Build Log -->http://www.stevemeadedesigns.com/board/topic/192208-hotdogs-f-150-build-log/ 2003 Mercury Mountaineer Build Log --> http://www.stevemeadedesigns.com/board/topic/114380-hotdogs-2003-mountaineer-build-log-20-removed/page__gopid__1602379#entry1602379 2008 Equinox Build Log --> http://www.stevemead...g/#entry1475764 Link to comment Share on other sites More sharing options...
Aistis Šestakauskas Posted November 1, 2014 Author Report Share Posted November 1, 2014 I've bridged amplifer and have two bridged channels. Right? So i run one dual voice coil subwoofer . i want to connect one coil to one channel so no more free channels left. Would be it right? And sorry for my english Link to comment Share on other sites More sharing options...
Aistis Šestakauskas Posted November 1, 2014 Author Report Share Posted November 1, 2014 I beleave Hotdog's post is helpful to me. Thanks for replies Link to comment Share on other sites More sharing options...
Hotdog Posted November 1, 2014 Report Share Posted November 1, 2014 You can run your subs series for 4 ohm's each sub Then bridge one sub to each channel. (NEW) 2004 F-150 Build Log -->http://www.stevemeadedesigns.com/board/topic/192208-hotdogs-f-150-build-log/ 2003 Mercury Mountaineer Build Log --> http://www.stevemeadedesigns.com/board/topic/114380-hotdogs-2003-mountaineer-build-log-20-removed/page__gopid__1602379#entry1602379 2008 Equinox Build Log --> http://www.stevemead...g/#entry1475764 Link to comment Share on other sites More sharing options...
Aistis Šestakauskas Posted November 1, 2014 Author Report Share Posted November 1, 2014 If i will connect each coil to each bridged channel i will push more power Link to comment Share on other sites More sharing options...
Hotdog Posted November 1, 2014 Report Share Posted November 1, 2014 According to manual it would be same power either way. I would bridge it my self that way you will get balanced power to each coil. There could be variance's on output on each channel. If you did one voice coil per channel each coil could potentially be seeing different wattage. Bridged would balance it out (NEW) 2004 F-150 Build Log -->http://www.stevemeadedesigns.com/board/topic/192208-hotdogs-f-150-build-log/ 2003 Mercury Mountaineer Build Log --> http://www.stevemeadedesigns.com/board/topic/114380-hotdogs-2003-mountaineer-build-log-20-removed/page__gopid__1602379#entry1602379 2008 Equinox Build Log --> http://www.stevemead...g/#entry1475764 Link to comment Share on other sites More sharing options...
