dual 2 ohm voice coil wireing
Aistis Šestakauskas
Series each sub to 4 ohm then parallel them to 2 ohm bridged at the amp.
Like this example
Can you post pics and maybe specs for the amp? I looked up what you said it is and it seems to be a 4 channel and only 2 ohm stable just want to make sure I found the right amp before trying to help. Also are you running one or two subs?
Here is the manual for it --> http://www.etc-shop.de/1und1_SHOP/Bilder/ETT/751141/751-141.pdf
It is a 4 channel amp. The amp can be bridged at 2 ohm according to manual. your put you wires from subs to the amp where the marking show bridged.
You would still have two channel left for something else
You can run your subs series for 4 ohm's each sub Then bridge one sub to each channel.
According to manual it would be same power either way. I would bridge it my self that way you will get balanced power to each coil. There could be variance's on output on each channel. If you did one voice coil per channel each coil could potentially be seeing different wattage. Bridged would balance it out
  • Who's Online   0 Members, 0 Anonymous, 397 Guests (See full list)
