Vertical & Parallel Slot Ports
SQL50
What are the pros and cons of both styles of ports? Or is there no difference in performance between the two? I've always wondered this, haven't seen a thread on here like that.. Might have overlooked it.. Thanks in advance..
Sketch of what your talking about?
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Alright, typical L port box, the port from the bottom to the top of the box looks like this |. & a slot from lets say from the bottom of the box to the other side on the width of the box like this ---
So like the port up and down the side firing forward or side to side firing forward?
If that's what your talking about it would really be install dependant.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
No side port.. For example subs up port back.. You can either have the port up and down or left to right..
Yeah its install and vehicle dependant.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • Who's Online   0 Members, 0 Anonymous, 2846 Guests (See full list)
