Thanks for reading I had my system built back in 98 in a nissan pathfinder I have 8 eclipse 15s and 8 zapco ag 1000 amps with two 205 at and the stock one. And a eclipse flip up monitor maybe 7001 anyway my symbil are chewed up so I want to run rca 's. I just don't know how to wire them up. Also subs are svc at 4 omh. I also have a 7 band zapco pre amp eq. My amps run bridged at 4 omh. Thanks for all the help I can get.
I believe you would need to use the symbilink to rca convertors (they will plug into your 6pin ports, and give you an rca output).
You would need to have the covertiors for every connection that doesnt have rca inputs/outputs so it may get expensive quick since the authentic ones are somewhat rare and expensive from some sellers.
Ebay will be your best luck most likely unless you possibly have a local zapco dealer.
http://www.ebay.com/itm/like/130862758302?lpid=82
http://www.ebay.com/itm/like/281457853745?lpid=82
http://www.ebay.com/itm/like/301263277759?lpid=82
It maybe best to buy new cables if you can find ones long enough.
http://www.ebay.com/itm/us-seller-ZAPCO-SYMBILINK-6-PIN-DIN-DATA-CABLE-6-FT-LONG-PATCH-CORD-SLDIN-06/251520902552?_trksid=p2054897.c100204.m3164&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20140407115239%26meid%3D3760bf51517e4124997a6f870d7f8007%26pid%3D100204%26prg%3D20140407115239%26rk%3D1%26rkt%3D30%26sd%3D301263277759
Other idea would be to figure what the pinouts of the plugs are and make your own adapters and or cables.
The plug looks like a S-Video connector but with 2 more pins, maybe you could do some digging around and come up with some more info.
You can use a rca splitter box from eq to box then amps the ags have rca an symbalinc correct
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
Personally I'd like to see some pics of this build. Sounds really sweet. Also clicked on the thread because trouble and Zapco don't really turn up in the same sentence..... that said, 15 year old amps you may start to get some electrolytic caps failing. On the bright side those amps are still likely worth the cost to repair.
Bowman box
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
i can't believe a 16 year old system is still working! that's amazing! i think the longest I've ever had something was 2 years.
jvc deck
stinger 1800 front
hc 2000 kinetic rear
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
type r comps front stage
6 kicker tweets rear stage
lots of great stuff
coming soon
ho alt
more bats
ct comps for front stage
more deadner
sweet amp rack
lots of L.E.D lights
  • Who's Online   1 Member, 0 Anonymous, 889 Guests (See full list)
