ace_ventura Posted February 23, 2015 Author Report Posted February 23, 2015 thx joe, now i have a better look on the box also with the right figure just need to find someone who can cut the holes and port perfectly, because i don't want tho do that with a jigsaw..
ace_ventura Posted March 10, 2015 Author Report Posted March 10, 2015 ik think i messed up when mounting the l port. its a little bit out of place 0.5cm on the back. i don't know if this is bad? or should i rebuild the box... i also have a new amp since yesterday a ground zero 1.2000mk2 this puts out: 1x650 watt @ 4 ohm 1% THD 1x1200 watt @ 2 ohm 1% THD 1x1900 watt @ 1 ohm 1% THD 1x1500 watt @ 2 ohm 10% THD 1x2400 watt @ 1 ohm 10% THD i have a little bit cash extra now so i whas thinking of addin an extra subwoofer since i will have to remake the box and go with a design for 3 subs with the new amp. what do you think?
Joe X Posted March 11, 2015 Report Posted March 11, 2015 Don't need to repeat the box, the issue is very small, about doing 3 subs, not sure if it is a good idea since you can't wire to 1 ohm and so the amp will deliver less than rated, don't think you will experience that much of an increase in performance.
ace_ventura Posted March 14, 2015 Author Report Posted March 14, 2015 OK thx for the info. Thought i had to remake the box because of the mistake i made. I Will buy 2 components sets of DD with a spl dynamics amp instead ;-)
notorious97200 Posted March 14, 2015 Report Posted March 14, 2015 You had very good help with those designs. Send this guy a bottle of wine or champagne ! How do you like the results, the sound ? Did you meter the system ? black BMW X1 2.0 l 192 hp OEM head unit, Amplifiers : Audison AP 8.9 with integrated DSP and Ampere Audio 1200. Focal ES 100 K in front doors, and Dayton RS 180 for midbass under the front seats. 2 SSA DEMONS 10" subs, in a sealed box. SecondSkin Damplifier on front doors, and Luxury Liner Pro for the cargo area.
ace_ventura Posted March 14, 2015 Author Report Posted March 14, 2015 yes indeed ! very glad with the designs of joe big thx i dind't had the time to finish the rest of the box because my father in law past away last week... but hopefully i will have the time this week to finish it.. and then i will try to meter the system
Ozzt Posted March 17, 2015 Report Posted March 17, 2015 Hi! i have the exact same subwoofers, and right now they're in a bandpass box which is.. Well.. Not very good. Was wondering if one of you could make me a design like OP got? Max external dimensions are Width 84 cm Heigh 42,5 cm Depth 38,2 Cheers
