2.1 Stereo in Home - How to run?
How should i run this? Should i just get a 5.1 receiver or is there a better way to go about this? I'm using it mainly for music but also will run my Xbox One through them.
Any receiver would work. Depends on the sub you are using. If it is powered just use high level inputs if you don't have a low level output on your receiver to your sub amp. If you are using a passive sub I would recommend you get a 5.1 or 7.1 with a powered sub output. I am using a 2ch kenwood and have rca going to my subs (yes more than 1) via rca splitter but that is just me.
You could be like me and get a 7.2 radio for a pair of components lol. At least I'm Bi-amping them.
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
nice big 2 channel for left and right, a dedicated monoblock for your sub.
I want something that can push 200 rms to each tower.
any ideas? no receivers put out more than 100-150
You won't hear a difference, but if you do it will be insignificant going from 100/150 - 200W.
probably not. But i guess i should have phrased the question differently.
How do you drive more power to speakers in home than the receivers offer? I am a real amateur at home audio. I know there are home amps but i dont know what brands to even consider or where to buy them.
You buy a true amplifier, but you'll never really find much around 200W+ and cheap. At least from what I remember. And even then you'll need something that outputs in RCA or sometimes they only accept straight wire, but with a bit of knowledge it isn't hard to make your own cords.
Ok, im not trying to go crazy here. SO is it safe to say just get a 5.1 and just run 2 towers and my powered sub off that?
  • Who's Online   1 Member, 0 Anonymous, 3383 Guests (See full list)
