Looking for my first Sub(s)
FineVisionz
Ok, I just want to see recommended 12in subwoofer set ups for around $500-$600 from now on. I don't care about the box size, I will figure away to secure the sub down. Also, I do not want to build my own box. So keep that in mind.
Thanks
If you don't build the box yourself you are probably have a tough time keeping things under budget. It can be $200-300 to have a box built. Building a box isn't really hard to do. Where are you located? If you aren't comfortable building one yourself maybe you can find someone to help you do it.
Builds:
Thanks
What I ment is I just want to buy a standard 12in sub box pre built.
You may think you want to buy a prefab box, but really you don't. While there are a few very limited exceptions, the vast majority of prefab boxes are junk. They almost never have enough port area, and are usually tuned way too high. They are built as cheaply as possible, so they use low quality materials that aren't well suited for the job. The only time I would use a prefab box is if it was for a sealed sub and I could visually inspect it to make sure it was properly constructed before I bought it. Even then I'd have to get it for just about free or I wouldn't bother.
Now its your truck and your money so you do whatever you want, but I'm going to tell you, and so will pretty much everyone else here, that prefab boxes are really not what you want to use.
Builds:
as always, the good stuff isn't cheap...and the cheap stuff....well...you know.
take your time, do a lot of research. ask a lot of questions. there are so many folks here that all share the same interest and goals. best of luck! :doit:
2007 Chevy Aveo Ls sedan
2 Sundown Xv2 on scv4k @ .5 ohm
2 pair RE XXX 6.5 components on sax200.4 @ 2 ohm
Big Three, Three runs 1/0 power from front to back, 1 ground front to back
Two runs ground from rear bank to chassis
XS power d3100 upfront, 3 Odyssey 2150s in bank
Singer 220 amp alt
  • Who's Online   1 Member, 0 Anonymous, 5614 Guests (See full list)
