Will one of these work or am i just S.O.L... 2 RE Audio MXV2D1 12s in a Lexus trunk
jadester
Ok so Ive been having hell trying to figure how to get this box to fix in the trunk of my Lexus
Car 1993 Lexus SC400
Subs RE Audio MX V2 12s
Amp DD M2a
A little info on the car... The trunk is basically completely sealed from the cabin. To open up some air flow I plan on removing the factory 8" subwoofer from the center of the rear deck... To further aid in air flow into the cabin I can also remove the two 6.5" speakers from the rear deck as well as two little panels about 4" x 4" that just pop right out... However I plan on just starting with the factory sub and going from there.
I've been getting conflicting specs from RE Audio about the recommended ported enclosure specs... The Website calls for 2.0 cubic feet for each sub. Now I've called REs tech support and they are saying that based on new testing the new recommended ported enclosure is 3.75 cu ft per sub with a 6" aero port... Like WTF? that's huge difference!
So the best that I can come up with is kinda in the middle 5.5 cu ft before displacement. However to get anywhere near that big I have to build into the spear tire well "oh well, could be worse" But because of the size of the subs "depth 10 1/4" I am VERY LIMITED on where i can actually place the port.
For the port I'm thinking of a 8" flared aero port @ 16.4" for a tuning of 35hz.... Correct if I'm wrong but if they are calling one 6" port that's 28.26 inches of port area... Using a single 8" is 50.24 inches of port area and 9.63 port area per cu ft... Should be ok???
So I'm thinking of using 5.5 cu ft gross... After port and woofer displacement puts it at 4.75 with a single 8" flared aero port
It looks like the only place I can place the port is dead in the middle on top facing up... How bad is this going to hurt me??? Now I do have an option on the placement of the subs. I can either do Subs up and Port up or Subs front or rear " With? you guessed it" port up...
So which is better Sub up / port up, Sub rear / Port up or Sub froward / Port up???
Subs front or back / Port up
Subs up / Port up
Rear Deck
Rear Seat
Trunk
Trunk Guts... Yes that is FU KING gas tank in the trunk
If you want my honest opinion get a new car. That metal that is separating the trunk from the interior of the vehicle is going to kill any spl that you may make. Sell the car and buy a hatchback /story.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
I agree a 4th would be great. But I already have the two subs which are dual 1 ohm. So if I'd drop to 1 sub that will put me at 0.5 or 2 ohms... And I believe I can make the 2 louder in a ported box vs a single in a 4th order
That trunk is completely sealed. lol. Good luck getting good SPL from that. (:
Would love to see pictures of what you've done as it's being done.
My trip to Meades shop - http://www.stevemeadedesigns.com/board/topic/172904-could-i-come-for-a-visit/
My vid at Meades shop - http://www.youtube.com/watch?v=YxinD-xwWWo
Had an amazing time bro! Die hard Meade fan!
-- My System -- 2001 Hyundai Tiburon --
(1) Rockford Fosgate 1500.1bdCP
(1) Rockford Fosgate 360.3
(1) Pioneer GM-D9500F
(1) Optima Yellow Top D34/78
(2) Pioneer TS-W3002D - 1000W RMS 12's
(1) iPhone 5s - 32gb White
(1) iPad Mini - 16gb Black ( 24/7 Headunit )
-- Wanted Upgrades --
(2) SP4 (15's or 18's)
(1) BC5500
(1) Mechman 320 amp Alt
(4) Optima Yellow Top D34/78
(1) Big 3 Upgrade Kit
Fix my other T1500.1bdcp
Gonna face subs forward. Open up the rear deck by removing the factory subwoofer enlarging that hole some so the air / sound from the Subs cone can come though. Remove the 6.5s and run two 6" aero ports though the rear deck...
Sounds like fun!
  • Who's Online   0 Members, 0 Anonymous, 1494 Guests (See full list)
