Where to face subs....Ports and subs on the same plain?
AstoSoup
A box can flex some without bracing, from what I've read some believe double baffles do no good and its more worth it to just brace.
Put some more deadener into it. That can help lower the resonant freq of the vehicle and as always helps with sq a lot.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
I am planning on installing my rear door speakers soon and will be taking the skins off to do so. I have some left over deadener, enough to do the rear doors so I will do them. Rear hatch has it on the outer and inner metal, plus the rear side of the plastic molding, so it's solid there. The latch busted from pressure so I have it screwed shut right now, it's tight but still rattles somewhere. Should I also do the side panels in the rear and the corners? Roof seems like a ton of work, I hate removing headliners... is it worth it to do the roof? The first box was 1.5" all the way around so I would think it wasn't flexing. This box has 45's and a generous coat of fiberglass in it, should help some.... If you want to check it out for yourself, here is my build log, shows the deadener I did, along with the inside of the boxes.
http://www.stevemeadedesigns.com/board/topic/192226-2003-ford-explorer-starting-small-working-my-way-up/
To the original question however, I know a lot of you have SUV's, what has been your best results in facing the subs and port? Am about to build this box and want to get it right, as I can't afford to do it a second time lol
Head Unit - Clarion VX709 7" DVD Touchscreen
Mid/Highs - Front Doors - RF Prime 6.5" component mids.
A. Pillars - RF Punch component tweets.
B. Pillars - RF Prime component tweets.
Rear Doors - RF Punch 5.25" mids.
RF Punch 3-way passive X-overs.
Mid/Highs Amp - MB Quart Onyx 360.4, 4 channel, 640W RMS.
Subs - (2) PowerBass 3XL 15, 1000w RMS, 3" flat wound coil, 562oz motor, 10" spider.
Sub Amp - Audiopipe GD6001 @.5ohm, clamped 2825RMS.
Box - 9.6 cu^3 net @35Hz, three 6" aero's.
Charging - Energizer 120Ah AGM under the hood, MaxLife 75Ah in the rear. Big 3, 140A aftermarket alt. (off brand)
Wires - Two JL Audio 2/0ga OFC. runs to rear, 4ga. power/2ga. ground to component amp (OFC), 1/0ga. OFC Knu Konceptz Kolossus Kandy everywhere else.
From what I've read and seen sub up and either port back or to the side.
Doing the roof and the rest of the cargo area should help greatly. I would do the front doors as well for better sound upfront.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Planning on doing as much as possible. Problem here is the cold temps that hit very early.... I don't have a garage and as we all know, that stuff don't stick in the cold.
I live in Alaska, I know all to well about the cold
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Yepp, so you know how much it sucks lol. I need a garage badly!
So am going to go with ports back, subs up.... two, 6" aeros @30Hz. Will be starting the build this week so if anyone has anything to add, would appreciate it. REALLY do not want to build this twice, lol
  • Who's Online   0 Members, 0 Anonymous, 1803 Guests (See full list)
