Design box for New DD 2512c with FS: 44.41hz
Eclipse25
Thanks for your help, and had seen the box designs ddaudio.com but the problem I see is that they are generic designs, and this sub with Fs: 44.41hz seems special. any other suggestions?
I suggest you re-read the DD website, their design philosophy and use their recommended box specs. Or if tl:dr, they only build and sell woofers that work well in those boxes they recommend.
Your EBP is at 44.98(45). The sub you have is best suited for a sealed enclosure. IF you want to ruin a ported box with that sub, it's not ideal at all. IF you want to run it ported, I'd suggest a higher tune, close to 40Hz.
Which is pretty much the cookie-cutter DD box,
I agree, but the sub they've CHOSEN to use for a 12" in that 2500 serious has an incredibly high electrical Q. I don't know what made them continue on with that design. I'm truly not bad mouthing, but perhaps they should just be full disclosure and advise that the sub is best for a sealed box(at least the 12").
P.S. I agree with you, that's pretty much on par for a DD sub, high tune.
the first: i will use the DD1 tu setup my amps and radio unit, I made a 2 box
a-port box tunning 45hz
b-port boxt tunning 37Hz (only for test)
comming soon Videos
You used the striker got the hatch as your ground? You shouldn't use that as a ground.
So wait, you were asking questions about enclosures yesterday and you've already made a box? I'm curious how it will sound.
I did not the box, send it to make. dimensions are 34in x 16in x 12in. The port: 3 in x 14.5 x 19.5in. Sound good but much "plac" for me. Its tunning around 44hz, i want to play sound 30hz or 35hz bass.... Its raining now. Coming soon video
You won't play 30 hz tuned to 44.
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
  • Who's Online   0 Members, 0 Anonymous, 3415 Guests (See full list)
