Just acquired an Audio Control 6xs. I want to get rid of the passive crossovers in my system. Question is can I use this to replace the passive crossovers in my component Soundqubed's without having to use separate amps for mids and highs. I have a soundqubed 4 ch amp but wanted to keep it separate front and rear.
I don't think so.I could be wrong on 6xs.sounds like you want a active setup.
A digital design x1 would been better choice ..but I wouldn't do a active front rear system.
So I would need a separate amp to run the tweeters and mids unless i put a bass blocker on the tweets which would defeat the purpose of the crossover. :shrug:
I had a 6XS back in the day but really can't remember. I still went passive on components but used it for 8" midbass and separation from front to back as well. At least 10+ years ago
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
6xs will work for active still need separate amp per speaker.its not a crossover like has freq and slopes.
Its more of a crossover say you have one set rca out on deck.And you need run front rear sub.it helps cause it will separate it for you on rca outs.
Yeah I knew it was for that reason. I was just trying to see if I could use it and still have front and rear separation on my components without using my passive crossovers. I have a four channel amp that I could run highs though two channels and my mids through the other two, but I'd lose my f/r separation. I will probably just run my passives for now until I get another amp.
  • Who's Online   0 Members, 0 Anonymous, 1081 Guests (See full list)
