Building a 6th BP. Where to start learning.
Courage68
Hello all !
Ive got a old 12" FI BTL fully loaded thats been sitting in my room for like 4 years now and i want to put her in a 6th order bandpass box powered by a old kicker KX1200.1 mid 2000's model
Ive built my fair share of box's over the past 10 years but i would like to advance my knowledge past sealed and ported box's and guide me on how to properly design/tune the rear and front sides of the 6th order design
Or even quite possibly perhaps someone whos bored enough and wouldnt mind just figuring out the vas and port tune for both sides of the sub.
Much appreciated.
I will also follow up with build pictures and test results.
Here is some general info on 6th order BP boxes: http://www.diysubwoofers.org/bnd/6thorder.htm
I'd try modeling stuff in WinISD just to see what you can come up with.
Other than that, experimentation is probably going to be your best teacher. One suggestion I would make is to design your box so you can change the tunings if desired. That should make experimentation a lot easier.
Builds:
Do the rear chamber the recommended ported airspace so there's cone control. You also can do small port area in the rear for cone control so you can tune the rear a little higher and still play below tuning. For the front, the airspace you do depends on how efficient/peaky you want it. The more airspace the peakier, I'd try around 1.5:1 or 2:1 ratio. As for tuning it's really preference, the rear is your low tuned side and the front is the high end. A lot of people say double your rear tuning for the front but I feel like that's too far apart and it'll create a valley between tunings in you bandwidth.
2006 Ford Explorer
2 Team AA/Sundown 15s
6th order
Ct Sounds 7k
4 PRV Mr500 8s
Rockford p1000-2
Team Subsonic Lows
6th are luck of the draw I feel. Build it and see what happens
2000 Toyota Camry With Sealed Off Trunk
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
Two DC Level 4 m2 12s
80 Mil Murdetmat
Gathering Parts For Wall Build.
Team DC Audio 2014 Member
I plugged your numbers in to WinISD and played around with it a bit. I have no personal experience with 6th BP boxes, but what you have seems pretty reasonable to me. I say build it and let us know how it turns out!
Builds:
  • Who's Online   0 Members, 0 Anonymous, 4861 Guests (See full list)
