Guest Posted December 19, 2014 Report Share Posted December 19, 2014 For example this amp has built in high level inputs.you can see two white female plugs on both side of amp.you would connect those instead of using RCA's. They will come with their own wiring. I am currently doing something like this through the rear speakers http://www.stevemeadedesigns.com/board/topic/194207-anyone-have-experience-using-the-high-input-on-an-amp/ Link to comment Share on other sites More sharing options...
dolarbilz Posted December 19, 2014 Report Share Posted December 19, 2014 For example this amp has built in high level inputs.you can see two white female plugs on both side of amp.you would connect those instead of using RCA's. They will come with their own wiring. I am currently doing something like this through the rear speakers http://www.stevemeadedesigns.com/board/topic/194207-anyone-have-experience-using-the-high-input-on-an-amp/ Perfect example Link to comment Share on other sites More sharing options...
conbon Posted December 19, 2014 Author Report Share Posted December 19, 2014 For example this amp has built in high level inputs.you can see two white female plugs on both side of amp.you would connect those instead of using RCA's. They will come with their own wiring. I am currently doing something like this through the rear speakers http://www.stevemeadedesigns.com/board/topic/194207-anyone-have-experience-using-the-high-input-on-an-amp/ Perfect example its confusing as shit. ill just stick with the locs 2013 Ford Focus Hatchback SE Kicker CS61234 Kicker 40CS674 Kicker KST25 Sundown Audio SA-12 D2 Rockford Fosgate t1000-1bdcp Rockford Fosgate t400-4 Audio Control LC7i Kinetik HC2000 0/1 Gauge Big 3 Upgrade Beer, babes, and bass. Link to comment Share on other sites More sharing options...
conbon Posted December 19, 2014 Author Report Share Posted December 19, 2014 They are pretty basic locs that will definitely get the job done, although personally I would probably get the Rockford bld-1 and use either y splitters from that or if your sub amp has rca pass thru/outputs then I would utilize that. I just really like my bld-1 compared to more basic locs that I had beforehand. Not saying the ones you picked wouldn't work either though. The single bld-1 would be an easier wire job too. how would the bld work bc theres only one output and the input is rca? 2013 Ford Focus Hatchback SE Kicker CS61234 Kicker 40CS674 Kicker KST25 Sundown Audio SA-12 D2 Rockford Fosgate t1000-1bdcp Rockford Fosgate t400-4 Audio Control LC7i Kinetik HC2000 0/1 Gauge Big 3 Upgrade Beer, babes, and bass. Link to comment Share on other sites More sharing options...
Pro7 Posted December 19, 2014 Report Share Posted December 19, 2014 It has hi level inputs I've gotten a blowjob and picked up my iphone behind her back to see what email notification I got from smd before Link to comment Share on other sites More sharing options...
conbon Posted December 19, 2014 Author Report Share Posted December 19, 2014 It has hi level inputs and what are these? is that from the speaker wire? 2013 Ford Focus Hatchback SE Kicker CS61234 Kicker 40CS674 Kicker KST25 Sundown Audio SA-12 D2 Rockford Fosgate t1000-1bdcp Rockford Fosgate t400-4 Audio Control LC7i Kinetik HC2000 0/1 Gauge Big 3 Upgrade Beer, babes, and bass. Link to comment Share on other sites More sharing options...
mothra Posted December 19, 2014 Report Share Posted December 19, 2014 where are you pulling signal from? stock head unit and do you know if it's actively crossover via an OEM amp or are you just assuming it's plug and play? if nothing changes, nothing changes You don't know what you don't know, till you don't know Link to comment Share on other sites More sharing options...
Broke_Audio_Addict Posted December 19, 2014 Report Share Posted December 19, 2014 It has hi level inputsand what are these? is that from the speaker wire?Yes and you would hook them up the same way as the amps pictured that you said are to complicated.Also if you have a factory amp you need to get the signal from before the amp. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals. Link to comment Share on other sites More sharing options...
