Rockford fosgate LOCs
conbon
For example this amp has built in high level inputs.you can see two white female plugs on both side of amp.you would connect those instead of using RCA's.
They will come with their own wiring.
I am currently doing something like this through the rear speakers
http://www.stevemeadedesigns.com/board/topic/194207-anyone-have-experience-using-the-high-input-on-an-amp/
Perfect example
Perfect example
its confusing as shit. ill just stick with the locs
2013 Ford Focus Hatchback SE
Kicker CS61234
Kicker 40CS674
Kicker KST25
Sundown Audio SA-12 D2
Rockford Fosgate t1000-1bdcp
Rockford Fosgate t400-4
Audio Control LC7i
Kinetik HC2000
0/1 Gauge
Big 3 Upgrade
Beer, babes, and bass.
They are pretty basic locs that will definitely get the job done, although personally I would probably get the Rockford bld-1 and use either y splitters from that or if your sub amp has rca pass thru/outputs then I would utilize that. I just really like my bld-1 compared to more basic locs that I had beforehand. Not saying the ones you picked wouldn't work either though. The single bld-1 would be an easier wire job too.
how would the bld work bc theres only one output and the input is rca?
Kicker CS61234
Kicker 40CS674
Kicker KST25
Audio Control LC7i
Kinetik HC2000
0/1 Gauge
Big 3 Upgrade
It has hi level inputs
and what are these? is that from the speaker wire?
Kicker CS61234
Kicker 40CS674
Kicker KST25
Audio Control LC7i
Kinetik HC2000
0/1 Gauge
Big 3 Upgrade
where are you pulling signal from?
stock head unit
and do you know if it's actively crossover via an OEM amp or are you just assuming it's plug and play?
if nothing changes, nothing changes
You don't know what you don't know, till you don't know
Yes and you would hook them up the same way as the amps pictured that you said are to complicated.
Also if you have a factory amp you need to get the signal from before the amp.
  • Who's Online   1 Member, 0 Anonymous, 902 Guests (See full list)
