Hansom Sarwan Posted December 19, 2014 Report Posted December 19, 2014 (edited) OK so i was going to sell my pair of Sundown Sa12s however i decided i would do a recone on both so it would be literally new again this is what i would like to know: -how much rms power can these Sa12 take to play them the best they can without causing damage to them dailyNote: People have said 1500rms.-2500rms so i would like to know from you guys who would know best Also box design is key i would like to get a box design for these to play a little low but loud meaning to play from 32-55hzsince most of the songs i would be playing is from 35-50hz and some hip hop would be lower but my purpose is for them to play loudly so i hope i can get help with a box design dimension i have to work with39" width by 27" depth by 28" high i would like the box could be like 39" width by 20-22" depth by 20" or less height i currently have a orion 1200d on the subs and not quite impress so ive decide i would sell the amp and upgrade the amp All help would be greatly appreciated Edited December 19, 2014 by Hansom Sarwan Quote
Broke_Audio_Addict Posted December 19, 2014 Report Posted December 19, 2014 600 rms. Quote That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
bentandbroken Posted December 19, 2014 Report Posted December 19, 2014 (edited) They are rated at 600 rms. But If you are pushing CLEAN Power to them up to 1000rms is fine. I have had one on ~1000+ watts for well over a year and it's still running strong. But I also dont beat the hell out it or clip it. *this is for one woofer. So two woofers you could put on 1500 to 2000 watts, but you need to set your gains with a dd-1 and i wouldnt do it on a budget amp. Edited December 19, 2014 by bentandbroken Quote Life's a trip. . . Don't fall.
Nealon14 Posted December 19, 2014 Report Posted December 19, 2014 I have had my 2 sa12's on close to 2k watts for a long time and they never got smelly even full tilt for a while. I have them in a 4 cube box after all displacements tuned to 31hz and it sounds good. I would say 1000 watts a sub for a daily application. Quote
hispls Posted December 19, 2014 Report Posted December 19, 2014 If you have to post this thread you have no business using these beyond the manufacturer recommendations. The "right box" isn't going to make a 2.5" coil hold 2000W worth of heat, nor is what brand of amp you use to make that power. Quote
