Sundown sa 12, which amp ?
commencal
Hi everyone !
I have the intention of buying a single sundown audio 12, but I don't know which amp to choose ... I found the SUNDOWN AUDIO SCV-1500D, the SOUNDQUBED Q1-1200D, or the SUNDOWN AUDIO SAE-1000D . Can you help me please !
Ps : My box will be tuned between 35hz and 33hz, and I listen lot of rap/trap/house song !
I'd get the scv-1500 and buy a dual 4 ohm sub, it will give you room to add another sub later if you want.
Ok, but i think put just one sub, i hesitate bettween the D2 or the D4, can you explain me the difference ?
The difference between D2 and D4 coil configurations allows you to chance the final resistance the amplifier sees from the sub. Determining how much power it is going to attempt to put out. Learn up on some Ohm's Law and you will understand it more.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
Getting the dual 4 ohm will allow you to wire it to a 2 ohm load at the amp and if you were to add another dual 4 ohm sub you could wire to a 1 ohm load.
Even if you only ever keep the one sub I'd still get the scv-1500 and the dual 4 sub because the amp will run more efficiently at the 2 ohm load.
ok ! thanks for your replies,
So the best amp for this setup is the sundown scv 1500, but the others are good too ?
The SA series subwoofer is a very UNDERrated subwoofer. Can take more than what it is rated for without problems. That amp puts out 800watts at 2 ohms. I would say for someone new, that would be a good number for it. And yes, all the other amps are good, the SCV is probably the most efficient of the bunch, and if down the line you want to get another subwoofer. You have the power to let them both shine.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
The soundqubed is the cheapest in the bunch. And still a good brand.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • Who's Online   1 Member, 0 Anonymous, 1062 Guests (See full list)
