speakers make crackling sound
Jared Lingley
How were the gains set?
you have the pwx? check if you havent damage them. also check if your crossovers r set properly.. i would get that same noise on stock speakers. i fixed it by setting my HU to 100hz and 80hz.. i have no subs so i need to get bass from somewhere. i still get that crackilng noise but not much i could hear and it goes away when i set my HU to 125 hz
My HU is set at 125hz. With my other amp, it was just fine at 100hz cranked to 57(highest is 62) with no distortion.
This amp is barley 45, and not even close to loud.
Another thing I forgot to mention, is when I turn the subs off from the HU, under "subwoofer 1" the crackling seems to disappear at idle and barley come back at mid rpm.
Set the gain correctly
How do you know your hu is clean to 57?
What freq and tone ( 0 -5 -10) are you using to determine this?
Any boost (loud setting, bass boost source level adjustment)?
Check grounds, fuses holders, power, speaker wire, and any other electrical connection.
Process of elimination.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • Who's Online   0 Members, 0 Anonymous, 1463 Guests (See full list)
