corey7733 Posted December 25, 2014 Report Posted December 25, 2014 hey hey my gf got a 2013 hyundai accent, i dont feel like hacking up her dash to fit a traditional head unit, and not sure if there is a dash kit for this car, and she likes the stock set up, but its lacking bass. i want to put her sub and amp in it, but i have never done a converter in a car. im looking for a well known product, and a place to get it. the car audio websites i usually use dont have what im looking for. would appreciate being pointed in the right direction! thanks.
sbg Posted December 26, 2014 Report Posted December 26, 2014 I never use converters. I take a pair of rca cut the ends off and take the positive and twist them together and tap them to a positive side of a speaker that has bass. Then twist the wires that covered the positives when you stripped them and make a Cassie ground. Done this in about 50 cars/trucks, from new to old . . never had a problem at all. 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
Motorboat KER Posted December 26, 2014 Report Posted December 26, 2014 I never use converters. I take a pair of rca cut the ends off and take the positive and twist them together and tap them to a positive side of a speaker that has bass. Then twist the wires that covered the positives when you stripped them and make a Cassie ground. Done this in about 50 cars/trucks, from new to old . . never had a problem at all. I recommend not following this. A LOC is easy to use. Takes 30 minutes at the most
Miguels Posted December 26, 2014 Report Posted December 26, 2014 i dont think he was talking about a LOC.. he says he cuts the end of rca and wires them to a speaker.. i think that would make any amp clip and dont suggest it. I never use converters. I take a pair of rca cut the ends off and take the positive and twist them together and tap them to a positive side of a speaker that has bass. Then twist the wires that covered the positives when you stripped them and make a Cassie ground. Done this in about 50 cars/trucks, from new to old . . never had a problem at all. my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
Miguels Posted December 26, 2014 Report Posted December 26, 2014 if anything i would use a 3sixty.3 and use the high level inputs my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
corey7733 Posted December 26, 2014 Author Report Posted December 26, 2014 yea i seen the pre made rca's that just wire to your speaker wires. not feelin that, thats not going to give me the lows that are required. i have no problem buying and installing a converter instead of hackin up some rca's. a 3sixty.3 will do what i need?
Miguels Posted December 26, 2014 Report Posted December 26, 2014 yes.. you get the signal from the head unit.. might be more than you need if you only plan on using one amp though my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
corey7733 Posted December 26, 2014 Author Report Posted December 26, 2014 http://www.sonicelectronix.com/item_74360_Rockford-Fosgate-RF-HLC.html?utm_source=criteo&utm_medium=paid&utm_campaign=criteoFB&utm_content=Rockford+Fosgate how about this little guy? it looks like there arent any gain settings on it like the other converters have. so im assuming it just has a preset, and you do the rest with your amp?
Miguels Posted December 26, 2014 Report Posted December 26, 2014 that works too my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
775Tundra Posted December 26, 2014 Report Posted December 26, 2014 Audio control lc2i 2003 Tahoe dc 7.5k dc level 5 15's (3) MMats 341's xs power batts lots of sky high cable dual alts(came off the sky-high gmc and don't know who made them) ipad in center console vu-din in center console all being ripped out and being sold
