2011 Honda Accord Sedan(Slow Budget Build)
Mids and tweetes
Sound deadening with Stinger Roadkill not the cheap peel n seal.
On this pic you can see I stuffed polyfill in areas that needed to be gaping open.
f7b47696-be3c-4ee8-bb78-673519dd8db5_zps
Custom made polyfill deadening............................................................................uhh yea
Weather stripping on the back of the enclosure so no rattling or no unwanted noises occur.
Again i will be changing the split loom to blue colored split loom. Also the weather strip in the rear window will be swapped out with One continuous clean line of weather strip pushed farther down. Its sounds really solid back there . There is absolutely no rattling or funky resonance back there now. ........( Surprisingly ).
To much going on in my opinion, can be just as loud with less but like how you used the carpet padding in the trunk area.
Nav-TV Zen V Audio Interface
AudioControl DM-608
(2) Stevens Audio Neo-Comp Full-Size Horns
(4) Faital Pro 6PR160 6.5"
AudioControl LC-6.1200
(1) Fi Neo 4.7 15" D2 in 3.74 Cubic Feet @ 27.70 Hz
Ampere Audio AA3800.1
Odyssey ODP-AGM48 Battery (Starting)
Odyssey ODX-AGM31 Battery (Trunk)
Big 3 - 2\0 Welding Cable, KnuKonceptz Speaker Wire & 1/0 Power Cable, NVX RCAs, Second Skin (Speaker Tweaker Pads, Damplifier Pro Mat), Diode Dynamics LEDs
Double post FTL
AudioControl DM-608
Triple Post FTL
AudioControl DM-608
Yea its a bit off an overkill but it doesn't nearly sound as bad as it looks.
For the subwoofer enclosure I will be using a pre-fab box from Atrend Enclosures. I didn't want a plain look so I went ahead and added some of my own touches to the box.
I also didn't like the flimsy spare tire cover so i rebuilt that also.
Pics...
The box is on the small side so I decuded to line the walls with polyfill to trick the CVX's.
Geting ready to trace the outline of the stock spare tire trap door. I know this wood sucks but im using it just for the pressed wood texture.
First piece cut and test fitted.
Decided this would be a good place for the second battery.
Second piece cut out.
Even found a location for the fuses in the process.
Bedliner time
Fuses test fitted.
Honda logo definitely not perfect!!
Doesnt look to bad.
Definite upgrade!!
Test fitting the enclosure (note: there is still work to do on the enclosure!)
Tommorrow I will post pics of how the amp rack was built.
:wtf:
Tiny update:
UPS came through today and dropped of my Audiopipe APCL 15001D that I ordered from Sonic Electronix. This thing is tiny but surprisingly it's pretty heavy.
I also wired the battery to the fuses in the trunk.
I like the fuse holder they provided.
Battery Ground
Wired up
I'm working on it right now at the moment so expect more pics soon.
I will be changing the split loom for the ground wire also. I don't like the black.
