gage120 Posted January 7, 2015 Author Report Posted January 7, 2015 If it's the one being sold at amazon for 120 then it's safe to say it'd nowhere near 3000 watts. If anything that's max watts which you will never see. how much do you think I will see?
Miguels Posted January 7, 2015 Report Posted January 7, 2015 If it's the one being sold at amazon for 120 then it's safe to say it'd nowhere near 3000 watts. If anything that's max watts which you will never see. my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
Miguels Posted January 7, 2015 Report Posted January 7, 2015 You would be lucky to get 1000 at 1 ohm. I personally won't wire that low. The amp has reviews of not working my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
gage120 Posted January 7, 2015 Author Report Posted January 7, 2015 Dang well what should I do? Do you have any ideas?
Miguels Posted January 7, 2015 Report Posted January 7, 2015 A cheap 3000 watt amp is in the $300-$370 range. Good 3000 watt amps are in the $700-$1500 range. You might see 800 watts at 1 ohm with dirty signal and who knows how long it will last One way to know is the fuse. What fuse does it have? Most 3k amps have a 300a fuse rating my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
khinds94 Posted January 7, 2015 Report Posted January 7, 2015 I had that SSL amp as my first amp. Man I'm telling you just spend like 250 for a used 1000 watt amp from one of the recommended brands om here. You have yourself a very good sub that needs clean power. Also what guage wire are you using for your power/ground? 03 Sable LS AA mayhem 12" D2 Sundown ZV4 12" D1 Tantric HD 12" D2 Tantric SHD 12" D1 Sundown X12 V2 D2 2.5 cu net Sundown 2000d @ 1 ohm XS Power XP2000 Sky High Sound Deadener Sky High wire Stock alt
gage120 Posted January 7, 2015 Author Report Posted January 7, 2015 I had that SSL amp as my first amp. Man I'm telling you just spend like 250 for a used 1000 watt amp from one of the recommended brands om here. You have yourself a very good sub that needs clean power. Also what guage wire are you using for your power/ground? 4 gauge for my power wire and a 8 gauge for my ground wire
gage120 Posted January 7, 2015 Author Report Posted January 7, 2015 A cheap 3000 watt amp is in the $300-$370 range. Good 3000 watt amps are in the $700-$1500 range. You might see 800 watts at 1 ohm with dirty signal and who knows how long it will last One way to know is the fuse. What fuse does it have? Most 3k amps have a 300a fuse rating Its like two 30's
Joe X Posted January 7, 2015 Report Posted January 7, 2015 This should be the amp, it's rated 1200W RMS @ 1ohm, not sure if it will do rated but may at least do 1K: http://www.sonicelectronix.com/item_23049_SoundStorm-SSL-EV3000D.html?show_tab=1
