blown sub?
MalibuMaxxx
What sub is it? i see 4 coil readings, is it a quad coil?
1997 subaru legacy outback
Four 15's in a almost wall
Rockford Fosgate t2500-1bdcp
Rockford Fosgate T400-4 on tweets
Rockford Fosgate T400-4 on highs
Rockford Fosgate T400-2 on midrange
Rockford Fosgate T400-2 on midbass
Optima Yellow top batteries
270A Singer alt (working on a bracket for a second)
Lots of Second Skin
There's other methods, push the cone down evenly on both sides and listen for coil rub (sounds like metal on metal rubbing because it is) or if you can't push the cone down at all it's screwed for sure. As far as multimetering the impedance if you have one side reading correctly and one side completely different that's a good indication. Can you actually see the voice coil on the sub?
take the sub out, and hook one coil to your amp. and barely turn the volume up. then switch. if one coil doesn't work or make the sub move.. you got a blown coil.
or you will hear a terrible noise
jvc deck
stinger 1800 front
hc 2000 kinetic rear
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
type r comps front stage
6 kicker tweets rear stage
lots of great stuff
coming soon
ho alt
more bats
ct comps for front stage
more deadner
sweet amp rack
lots of L.E.D lights
new deck (thinking 80 prs, or flip out)
I wouldn't be hooking any of my amps up to a coil that read 0.0...
Static drops are my bag.
  • Who's Online   0 Members, 0 Anonymous, 11877 Guests (See full list)
