Burp box basics. Need some help.
BigManAC
Im thinking about building a burp box strictly for when I compete. My box right now is sealed off but is also removeable. Ive been looking at topics and saw that in order to find my cars peak fq I need to do a sweep in a sealed box so im going to build a plug for my boxes port and do it that way. Going off of parameters, what needs to be different in a burp box. Recommended port area, ratio ect.
Here is my box as of now. Its gotten me a 144db @ 32Hz and just want to see if I can improve that.
Other info: 2001 Saturn L200, Fi BL 15'' on SQ2200 @1ohm
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- (4) Crescendo PWX 6
- Cadence XA250.2
SUB STAGE:
-Fi Audio BL 15 (Sealed Off)
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
- SkyHigh OFC power/speaker wire
- Big 3 with SkyHigh 0gauge
Build Log: Click Here
Scores: 146.5db @ 29hz Outlaw
There's a newer version of Torres, I think this one was buggy. Try the latest one to see if there are any changes
The L@zy Hoe
2005 Chevy Tahoe
2,500 Watts of Highs/Mids
4 10 midrange
4 6.5 midwoofers
4 Tweeters
6 Supertweeters
2 Lithium 80AH Batteries
24K Watts
4 Custom 18s
Quad alt setup Rebuilt 250amp and 3 370s
Interior work by Lone Star Auto Works
The Build Log
Like Loud Bass? Click Here!
On 12/5/2014 at 8:06 PM, juan777 said:
See yall there, I'll be the drunk Mexican with aviators on.
On 12/6/2014 at 10:32 PM, boom50cal said:
I did see Juan LMFAO! He REALLY WAS the drunk mexican with Aviators on!
I'll be doing a single 15" this year too! What works for me us tune high and use medium to small boxes! Are you planning on bassracing or just burp?
Ray
2012 Jeep Grand Cherokee Laredo
Kenwood DDX9702S Connected with iDatalink Maestro
Cactus Sounds PF K5 w/ 1 Sundown Audio Zv.4 "10
Cactus Sounds PF 250.4 w/ SSA Evil 6.5" Midranges & Evil 1's Tweeters
Northstar  D3100 in the rear
Most likely just burp. I was thinking about dropping the net to about 3.5cuft
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- Cadence XA250.2
SUB STAGE:
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
i wouldnt trust a program....
try making a test box with a side that is adjustable to increase/decrease volume. also a port or several ports that are also adjustable (pvc is cheap and easy to adjust)...
then test test test test test test ....
edit: assuming you have a db meter to compare measurements-
X2....
My first box will be 3c/f with 2 6" zeros then 1 8"! Second box wilk be 1.5c/f with a 7" adjustable aero!
Be ready to chop, cut & rebuild!
Ray
I just didnt know if there was any rule of thumb to go buy like a certain amount or port area. I will be doing either an aero port or depending on the size a pvc port.
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- Cadence XA250.2
SUB STAGE:
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
Find resonant frequency, build a box with a good amount of port AREA(not per cube bullshit) and an amount of airspace that can control your sub mechanically and avoid launching a cone. I know we are only talking about a 2200 on a 1500W sub, but it still needs to be said. Don't put the sub in double the recommended volume obviously :)
Resonant frequency is going to be the key and tune right at THAT frequency.
Large port small box for the one that I built a while ago I ended up with about 1.3 cubes for a single 12" dd redline and a 6" flared PVC port for a 600rms sub it handled 5800 watts for a lot longer than I expected. Port on opposite side as meter test a lot
  • Who's Online   0 Members, 0 Anonymous, 4682 Guests (See full list)
